Pictures of my throttle body from above with views of throttle adjustment screw and idle control screw.
Throttle Body
Throttle adjustment screw.
Idle speed screw.
Re: Series 1 1990 2.0i XM Auto Throttle Body
Tim Young
- XM newbie
- Orga / RP numbers: 2.0 XM Si Auto 1990 (Saloon) RP4960 Paint Code ERH Vert Amandier
2.5Tdi Est 1997 Silver. Replaced with a 2.5Tdi Est in maroon from Savoy garage and was written off there undergoing titivation. Approx' 2022. - Location: LE2 3FF Leicester
Re: Re: Series 1 1990 2.0i XM Auto Throttle Body
Assuming this is connected to an idle speed issue, the lower screw is the throttle setting for idle speed and isn't the upper screw the stop for the secondary throttle flap, which should be closed until the main throttle flap is about 3/4 open.
That will then give the minimum volume of air the engine can be fed with and any additional air required for cold starting will be via the supplementary air valve.
The throttle switch needs to sense the throttle closed/open. It should click as the throttle is opened a little and closed.
