MyXM Vid.
spitroen
MyXM Vid.
Post by spitroen » Mon May 21, 2012 10:37 pm
Sorry about the sound,had flu,plus the mike on blackberry is rubbish. Just wondered, is this a version1 or 2 XM?? http://youtu.be/RQwKBd3woGo
Tony.
S1 Auto prestige 2.0 turbo petrol. RP 6064. Production date. 19/06/93.
Saab 9-5 HOT 2.3 Aero.
Re: MyXM Vid.
Post by Dieselman » Wed May 23, 2012 4:37 pm
It's a late series 1 car, sometimes referred to as S1.5. Overall, it looks like a pretty tidy car so just needs the minor electrical bits sorting to make it all good.
All prestige models were S1 cars, it is effectively SEi spec with a few differences.
Re: MyXM Vid.
Post by XMX » Wed May 23, 2012 5:19 pm
Dieselman wrote:It's a late series 1 car, sometimes referred to as S1.5. Overall, it looks like a pretty tidy car so just needs the minor electrical bits sorting to make it all good.
Albeit sporting an S2 nose-cone/grill ;)
[youtube]RQwKBd3woGo[/youtube]
If you care to check it out again !
Re: MyXM Vid.
Post by Dieselman » Wed May 23, 2012 5:24 pm
Agreed. It could do with an S1 nose-cone to make it original.
spitroen
Re: MyXM Vid.
Post by spitroen » Fri May 25, 2012 7:12 pm
That's why I was slightly confused, as the front looked S2, and the chevrons were in the middle of the grill, and larger.
Tony.
spitroen
Re: MyXM Vid.
Post by spitroen » Fri May 25, 2012 7:16 pm
Posted another vid of the xm, had it set to highest height setting, as my house is down a dirt track and very bumpy.
http://youtu.be/1uIAqhsGLp0
Tony.
Re: MyXM Vid.
Post by Dieselman » Sat May 26, 2012 9:07 am
I saw the warning lights, is the left one "high Temp"?
You can read the engine error codes with a simple LED tester, alternatively there may be a member near that has a Lexia.
Has the rear o/s wing and rear door been painted, the lacquer looks flat and needs a polish, otherwise that looks a very tidy car.
spitroen
Re: MyXM Vid.?
Post by spitroen » Sat Jun 02, 2012 10:18 pm
yes its seems the lacquer has come off, strangely around both rear wings, i think it must be were it had been kept by a previous owner ?
The temp light says on, because for some reason the car thinks its overheating even though its not, thats why the cooling fan are constantly running.
Tony.
Re: MyXM Vid.
Post by Dieselman » Sun Jun 03, 2012 7:57 am
The Hight Temp warning is likely to be the sensor on the thermostat housing or a wire shorted to Gnd, but the sensor is more likely.
citroenmad
Re: MyXM Vid.
Post by citroenmad » Mon Jun 11, 2012 10:06 pm
That is a very tidy looking Xm, my XM is identical to that, albeit mine is black. They share a very similar number plate too, mine is L92 KBL ... :D
Having the Air con on will also run the fans constantly.
If you do have a bumpy track to your house, I would recommend the intermediate setting, as its very bumpy in high with no suspension travel.
Nice car! 8-)
