XM Vin numbers
Re: XM Vin numbers
Post by Dieselman » Tue Feb 17, 2026 6:27 am
MelbMan wrote:
Mon Feb 16, 2026 7:27 am
Hi!
Hoping to decipher my VIN plate on a newly acquired 1992 XM 4 cylinder 5 speed. And the other codes on the plate
VF7Y3AC0006AC8441
1845
3145
1 - 1020
2 - 825
Vf7 = France, Citroen.
Y3 is Xm, Series-1 body.
AC = Xu10, 2.0 injection, 8 valve engine with manual gearbox, saloon.
0006 = the sixth series run of the AC type.
AC again...Engine/ body type
8441 = Unique serial number of that car.
1845 = Gross vehicle weight
3145 = Gross train weight
1 - 1020 = Max front axle load
2 - 825 = Max rear axle load.
Most of the information you will need for your car can be found in the Citroen Private Car Books, found in the Self Help Files section of the forum.
viewtopic.php?f=13&t=11023
Specific engine technical information can be found in the Engine Management Technical information thread, also in the Self Help Files section of the forum. viewtopic.php?f=13&t=10588
