XM Vin numbers
XM Vin numbers
Post by MTXM »
I have never really thought much about how a Vin number is made up, but I understand the sequence is as follows:
Make Model Car ID
XXX XXXXXX XXXXXXXX
Here are a couple of my XM as examples:
1989 V6 Exclusive
VF7 Y3AG00 00AG0999
1992 2.0 sei turbo
VF7 Y3AX00 00AX1256
Is it reasonable to assume that the first 2.0 sei for example would be numbered say 00AX0001, or would it be 00AA001, or might that be the first XM? My question really is are the letters in the car ID model specific, or could you possibly get two XM with the same ID? Please do let me have any comments.
With regards,
Matthew T.
kenhall
Re: XM Vin numbers
Post by kenhall »
Loads of VIN decoders on Google - here is one example http://vindecoder.eu/citroen
Ken
Re: XM Vin numbers
Post by MTXM »
Many thanks Ken, although it was not decoding I needed but rather a desire to understand the car ID sequence. If my first suggestion is correct then of the two examples given the V6 Exclusive is no. 6999 of that model and the 2.0 sei is no. 25,256. It might make sense in the case of the V6, but as the 2.0 is an early example and only released that year could they have produced as many as 25K so quickly? With regards, Matthew T.
Re: XM Vin numbers
Post by MTXM »
Interestingly my two mid-1990 production V6 have chassis numbers ending 01AG7721 and 02AG7470 with a difference of only 10 between the RP! As all three cars have 'AG' that suggests to me that the first V6 XM was 00AG0001. According to the table of figures recently posted the total V6 production between 1989-1990 was around 25,000 cars and as 00AG0001- 02AG9999 makes almost 30,000 cars I think my theory does make sense. Regards, Matthew T.
Re: XM Vin numbers
Post by xantia_v6 »
Did you see viewtopic.php?f=2&t=2598 for a discussion of vin numbers?
The usage of the 11th digit is interesting, I don't think it is sequential with the serial number, as it is a 1 on my ES9, and there were certainly fewer than 9999 ES9 BVMs built.
Re: XM Vin numbers
Post by MTXM »
Many thanks for that and I had forgotten the earlier thread! Amongst other things I now know that AG means V6, which does after all repeat elsewhere in the Vin, while AX is 2.0i turbo. On the use of the 11th digit, it seems for the early V6 that the series ran together as for my two cars the RP are just one week apart, unless it distinguished the manual and auto box fitting? Regards, Matthew T.
Re: XM Vin numbers
Post by xantia_v6 »
For Peugeot, the vin number is quite systematic, ( http://www.bba-reman.com/forums/Topic122354.aspx). Pity Citroen did not use the same scheme.
Re: XM Vin numbers
Some RTA VIN pages:
Sorry no V6 data as that book has gone to storage.
Re: XM Vin numbers
That's great John.
MelbMan
Orga / RP numbers: VIN VF7Y3AC0006AC8441
Re: XM Vin numbers
Post by MelbMan »
Hi!
Hoping to decipher my VIN plate on a newly acquired 1992 XM 4 cylinder 5 speed. And the other codes on the plate
VF7Y3AC0006AC8441
1845
3145
1 - 1020
2 - 825
Any assistance appreciated
Thanks, regards
