Morning guys,
I noticed yesterday that site was sluggish and unresponsive a few times that I tried to access it from work, and it was totally unavailable for an hour or so in the evening, even though the server was running.
Upon further investigation I found that something is causing the machine to reboot every 24 hours or so, and also crash with hardware errors. At this moment in time I'm not 100% sure what's doing it, could just be a dodgy driver or similar, but I'll need to take the machine offline at some point over the weekend to properly investigate the cause, and put a stop to it.
In light of this, there's likely to be a couple of hours of intermittet availability, but I'll try and minimise it as much as possible.
Sorry for any inconvenience.
Ciarán
Possible downtime this weekend
Ciaran
- Site Admin
- Orga / RP numbers: 1234
5678
91011 - Location: Ireland
Re: Possible downtime this weekend
Dont worry about it Ciaran, you'r doing a sterling job keeping it going for us.
^ What he said.
I noticed the forum was down..thought you might've got water in the electrics..
colinxm
Thanks Ciarán, fantastic to have a site owner that actually cares
Best wishes Colin.P
Best wishes Colin.P
1995 Cit XM 2,1 TD Silver Estate - deceased
2004 Opel Vectra Estate
2008 Kia Ceed td
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
2008 Kia Ceed td
1998 Ford Puma
1979 Triumph TR7
- jorgy
THANKS Ciaran !!
George
George
Yep thanks for all your hard work Ciaran!!
Us and Ebay both off tonight, wasn't anything to do with you was it Ciaran?
Ciaran, whatever you did last night has worked, the forum is like lightning now. THANKS.!
