V78 LAB
Assich
Orga / RP numbers: 5678
V78 LAB
Post by Assich »
A previous car of mine, is this still on the road?
1992 build 2.0i Prestige Auto
Re: V78 LAB
It's not in the register and th last M.O.T expired in November last year, in Nov 16 the advisory sheet was long..........................and brown.
Mileage 177,159 miles
MOT test number 4527 2322 8746
Test location unavailable until further notice
Expiry date 27 November 2017
Advisory notice item(s)
Front Vehicle structure has slight corrosion (6.1.B.2)
Rear Vehicle structure has slight corrosion (6.1.B.2)
Nearside Front Inner Vehicle structure has slight corrosion sill (6.1.B.2)
Nearside Rear Inner Vehicle structure has slight corrosion sill (6.1.B.2)
Nearside Outer Vehicle structure has slight corrosion sill (6.1.B.2)
Offside Front Inner Vehicle structure has slight corrosion sill (6.1.B.2)
Offside Rear Inner Vehicle structure has slight corrosion sill (6.1.B.2)
Offside Outer Vehicle structure has slight corrosion sill (6.1.B.2)
Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
Offside Front Brake hose slightly deteriorated (3.6.B.4d)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Front wing slightly insecure
Offside Rear Fluid suspension unit interconnecting pipe corroded but not seriously weakened (2.4.D.3)
Nearside Rear Fluid suspension unit interconnecting pipe corroded but not seriously weakened (2.4.D.3)
Re: V78 LAB
Post by MTXM »
That does not look good Dean and no prizes for guessing what happened next!!! Regards, Matthew T.
David Hallworth
Re: V78 LAB
Post by David Hallworth »
The gearbox on the car was rebuilt by CitroJim and Chris570, then he had problems with the engine I believe as it started pressurising the coolant.
Not sure of it's whereabouts now though.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Re: V78 LAB
Post by xantia_v6 »
If that is the car I think you are referring to (Mauritius blue ES9), I think that Chris changed the engine, fitting one from a Xantia I broke. He kept it for several years after, I never heard of him using it on the road. I don't remember hearing of it being sold either.
renault760
Re: V78 LAB
Post by renault760 »
That MOT list sounds to me like a load of ....... "Slightly, corroded", "slightly deteriorated," "corroded but not seriously weakened".
Sounds like a description of practically any used car over 10 years old. Do they expect all cars to turn up looking like they have just left the showroom? I've just been reading about new changes coming into force in May with regards the MOT test.
As someone pointed out, the number accidents caused by car defects is small, (usually tyres I would suggest,) yet we pay a fortune to get our cars through the test every year.
On the other hand, the number of accidents caused by bad driving is huge, yet we get tested ourselves once a life time.
The MOT in my opinion, when introduced may have been a good idea but over the years it has just become one big money making scam and a scheme to which the authorities can point to and say "aren't we a safety conscious lot".
LG.
