Steering Rack
Shaun17
Steering Rack
Hi Has anyone got a steering rack for a 2.5 XM Thanks Shaun
Re: Steering Rack
I have a 2.1 rack, is a 2.5 one actually different, or just the track rods?
Re: Steering Rack
Track rods and track rod ends are larger but interchangable.
Only restriction is each rod and end must be the same.
Shaun17
Re: Steering Rack
I have got problem with my Mark 2 XM 2 The steering is very hard abut not all the time.They have checked all the hydraulics and think it is the rack I have my car at what used to be Medway Citroen Any ideas Shaun
Shaun17
Re: Steering Rack
Do you think it could be track rod ends??? Shaun
- Jan-hendrik
Re: Steering Rack
How long has this been going on? Did the symptoms appear all of a sudden, or was it something that started small and then gradually became worse? Has any work been carried out on the hydraulic system?
Re: Steering Rack
Air in the hydraulic fluid can produce stiff and notchy steering, and lack of smooth power assistance.
Might be worth checking this out.
After driving the car for a short while (or running the engine and moving the steering wheel) dip a sample of LHM from the reservoir with a small clear container. Fluid should not contain bubbles, even microscopic ones.
Re: Steering Rack
Siezing up uj joint can also cause issues too... useually lumpyness in sections
- Jan-hendrik
Re: Steering Rack
Yes, that's something I have experienced and had in mind when asking my questions.Air in the hydraulic fluid can produce stiff and notchy steering, and lack of smooth power assistance.
Shaun17
Re: Steering Rack
its happen over two months and the hydraulic pump has been changed.Jan-hendrik wrote:How long has this been going on? Did the symptoms appear all of a sudden, or was it something that started small and then gradually became worse? Has any work been carried out on the hydraulic system?
