My XM from Portugal
Z3N85
My XM from Portugal
Post by Z3N85 »
It is a 1991 XM 2.1 Turbo D, i´m not sure if it is a SED. Came to my house this month, i hope i can learn all of this amazing car whith all users. Thank you. ;)
Re: My XM from Portugal
European spec cars didn't follow hte same naming configuration as UK spec cars, so it will just say Turbo-D12 on the wing instead of a version type. The European versions were Seduction, Harmonie, Pallas, however, it was possible to spec almost anything as optional extra, such as hte steering wheel buttons on your car.
You description reads like our SED trim level and the appearance is the same.
Most parts on that car appear like early items, but the wood trim came a bit later. Can you post up the RP number, please.
Z3N85
Post by Z3N85 »
Dieselman wrote:European spec cars didn't follow hte same naming configuration as UK spec cars, so it will just say Turbo-D12 on the wing instead of a version type. The European versions were Seduction, Harmonie, Pallas, however, it was possible to spec almost anything as optional extra, such as hte steering wheel buttons on your car.
What is the RP number?
djg
Orga / RP numbers: 7903
Post by djg »
Also called ORGA, a four-digit number paint stamped on the A pillar near the hinge as you open the door. It simply communicates the day the car was assembled on and is used in parts catalogs and other factory documentation to timestamp any modification.
Bye,
Gábor
Z3N85
Post by Z3N85 »
djg wrote:Also called ORGA, a four-digit number paint stamped on the A pillar near the hinge as you open the door. It simply communicates the day the car was assembled and is used in parts catalogs and other factory documentation to timestamp any modification.
Thank you, tomorrow i will see that.
raynoon
Orga / RP numbers: 6043
Post by raynoon »
Hello and welcome! A very nice XM you have there! Also, behind the drivers side headlight there will be a code, this tells us the colour of your car, could you supply that too?
Abrigado!
Z3N85
Post by Z3N85 »
djg wrote:Also called ORGA, a four-digit number paint stamped on the A pillar near the hinge as you open the door. It simply communicates the day the car was assembled on and is used in parts catalogs and other factory documentation to timestamp any modification.
Hello sorry but i was busy during the week. So the ORGA number is 5280, where can i see the informations about it?
Thank you.
Z3N85
Post by Z3N85 »
raynoon wrote:Hello and welcome! A very nice XM you have there! Also, behind the drivers side headlight there will be a code, this tells us the colour of your car, could you supply that too?
Abrigado!
Hello, yes the color code is ETW- Gris Silex
raynoon
Post by raynoon »
Hello, using the calculator, I can see your car was made on 24th April 1991 http://www.citroen-ds-id.com/gen/Gen_Organr.html" onclick="window.open(this.href);return false;
raynoon
Post by raynoon »
It's also the same colour as my K-BAN
