Calling all Xantia owners.....
I need a little help... Can anyone with a Xantia take a pic and measure the Total boot window sticker the cars came with for me.
I have had an inquirey today for some and as I haven't done any yet, this is a great opportunity to do some. I have been meaning to do these for ages.
Many thanks :)
Eddie nuff
Post by Eddie nuff »
Depends which one you want:-
On the NSR - 1150mm x 480mm
OSR - 1000mm x 450mm
It's possible that they are both the same size as they are both original stickers (obviously from the state of them) and look as though they are inverted.
Re: Calling all Xantia owners.....
Interesting. They are slightly different, the upper one has more rounded chevrons.
I wonder if the sharper one is the original design, for early cars, the more rounded one a later design for later cars.
The normal mounting place is OSR.
Neil you star. :D many thanks.
They really are quite different. The lower sticker is closer to the Xm one, but the top version is quite different.
I think the sharper one is the early versions and the rounder version for mk2 cars. The C5 one is quite similar.
I will be making mine internal rather than external window stickers. They just won't last being exterior stickers.
Eddie nuff
There is a S1 I know of. I'll see if I can get a pic.
Post by xantia_v6 »
I have been trying to remember which sticker(s) were on my 1997 Xantia exclusive. My feeling is that it had both "positive" and "negative" Total stickers, and the " Xantia air conditioned luxury" sticker across the top of the window.
I will look at Xantia around here and see what they have, I saw a mk2 today with the "negative" sticker on the right side, but could not see what was on the left.
Thanks Mike. The Xantia I keep seeing about, including one today infact, don't have anything at all. So it seems it's quite a find to see a Xantia with boot stickers still.
Post by xantia_v6 »
I saw 3 this morning: an early car with chevrons on the bonnet, a slightly later car (pre airbag), and a mk2. All had the "positive" sticker on the rhs. The "negative" sticker might be uk -only, perhaps getting double sponsorship from Total?
I took photos of a couple if you want them.
That would be great Mike if you don't mind. :)
I will do some more research at the national. You might be right about UK and French cars being different.
David Hallworth
Post by David Hallworth »
My Activa still has the stickers on it. I'll get you a picture tomorrow, Russ.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
