Hi everyone I need to locate stocks of LHM seals, does anyone know of a manufacturer or stockists of LHM Seals?
I do not have a Citroen anymore but did have a DS, this is for another project.
LHM Seals
Re: LHM Seals
I am sure Pleiades will be able to help you www.classiccarwebsite.com/pleiades. With regards, Matthew T.
Re: LHM Seals
Been buying these in during the last month.
3.5mm, 4.5mm & 6.35mm seals and nuts.
I got some from a GSF remainder stock order.
Some along with 4.5mm & 6.35mm CuNifer pipe came from Malcolm Lockwood
http://www.mlockwood.org.uk
01274 640590 mobile 07966629633.
If you are buying 3.5mm nuts avoid genuine Citroen ones.
The flare nut flats on these are far too small for a reasonable life.
The other 3 suppliers mentioned in these posts usually supply aftermarket nuts with wider and deeper flats.
My stock of 3.5mm nuts came from the UK manufacturer but they have now ceased production and I cleared the reminder stock.
GSF branches often deny stocking these items.
I can provide their part numbers and a very helpful contact if needed.
robertmnorton
Re: LHM Seals
Hi , I got mine with the order from Franzose.de, but got additional seals from eurocare by return of post. I'm currently retubing complete front to rear due past 2 years mot advisories.
robertm
robertm
Re: LHM Seals
Pleiades are the cheapest supplier of LHM seals that I know of.
