How to removed front trim panel
auto4001
XM newbie
Post by auto4001 »
Due to my xm water leaked around the bottom blower air area every time for washing or raining. So I want to removed front trim panel to check it. Please told me.
Regards,auto4001
Re: How to removed front trim panel
Hi Auto
The cross panel under the windscreen is fixed with 2 screws each side.
These screws are hidden under the triangular covers at each end of the cross panel.
The covers unclip but not easily.
Push down from the top and pull out at the bottom of the cover.
The clips are little plastic projections cast as part of the cover.
They often break off when the covers are removed.
auto4001
XM newbie
Post by auto4001 »
Thank a lot John.I will try to do it.
I always unclip the end covers at the top first, then push down to unclip the bottom hooks, to avoid breakage.
