Hi Folks,
Following the first long journey since the rebuild I thought I'd report back on the SED. For this years holiday we flew from Gatwick so the XM carried 4 of us and our luggage there and back (after a week away). Before the trip I checked over the usual items, tyre pressures, fluid levels, etc. replaced the last few unfitted pieces of interior trim, got the fuel gauge working and put £50 of biodiesel in the tank and 15 litres of SVO - this according to the fuel gauge pretty much filled the tank (it wasn't empty to start with). The journey there and back was uneventful, great comfort, enough power and after 400 miles there was just under half a tank left. Cruise control and working A/C would have been nice though. Currently the XM is running on a bizarre mix of spheres that I happened to have in the garage already and a couple I bought specifically. It's a long story but currently I have the proper front spheres on the back and a pair of front comfort spheres on the front. This gives a very soft ride that is good on most roads though I wouldn't recommend going fast (60+) on a undulating road. Because of the type of hydractive system fitted I can switch the XM into hard mode (it does stay in hard mode according to my status LED) and tighten up the handling if needed. I don't know as yet as to whether I leave the XM's suspension like this or not but currently it's still running on Hydraflush and I think the softer and subsequently increased suspension travel helps the flushing process. She's now up to around 150,000 miles with 1,600 miles since the rebuild, so I think it's time to give her another oil change before long. Same for the gearbox too.
Steve
2.1 SED Progress Report
- steelcityuk
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Re: 2.1 SED Progress Report
Good to hear it's going Ok Steve, just keep using it.
- steelcityuk
Hi Folks,
Another short update. Oil and filter changed as I intended before a nice few days in Berkshire/Oxford which clocked up another 400 miles give or take. The XM went well, apart from the on/off fuel gauge. The ride was really nice and smooth, the engine didn't miss a beat and fuel consumption seems good. The car will be off the road from the end of the month so I can take my time over some jobs over the winter - new glowplugs, outside air temperature sensor needed, A/C recharge, fuel gauge fixing and maybe a serious audio install.
Steve.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
I need some fuel gauge fixing and other electrical things to sort out on my 1990 Turbo SD. I forgot about those niggles! More work to do!!! Arghhhfuel gauge fixing
