naf laptop button
naf laptop button
Please excuse the title put ive got to type without a.......... (the letter between J and L on your eyboard) it just stopped woring, is it a real pita to get the eyboard out of a laptop (toshiba) or is it easy and im just not seeing it.........please help
Re: naf laptop button
KriKy, that is a bit of Krap lucK Dean!
Sorry, Kan't help you out!
Good LucK
Good LucK
hobblerian
http://www.laptoprepair101.com/laptop/2 ... -keyboard/
Not sure how old the guide is, follows on from the sony one.
Previous XM- 1990 H 2.1TD SD
Current XM- 1997 P 2.1TD VSX
There is a lazier answer Dean.
Just substitute another character whenever you get to that
aw£ward letter £ey!! We'll all get used to it and see it as a
particular quir£ of messages from you...
Sorry, you £now I couldn't resist!
Andrew
Andrew
Lift out the strip that runs along the rear of the keyboard then the strip-down should be obvious. I can't remember whether the keyboard comes out next or has to be unscrewed from underneath first..Dean wrote:Please excuse the title put ive got to type without a.......... (the letter between J and L on your eyboard) it just stopped woring, is it a real pita to get the eyboard out of a laptop (toshiba) or is it easy and im just not seeing it.........please help![]()
Ciaran
- Site Admin
- Orga / RP numbers: 1234
5678
91011 - Location: Ireland
What model of Tosh is it Dean?
They vary a little. I may have a keyboard for your particular model lying around somewhere...
Ciarán
Ciarán
Ciaran
- Site Admin
5678
robert_e_smart wrote:KriKy, that is a bit of Krap lucK Dean!
Good LucK
SteveLP
I always find that turning it upside down and banging the keyboard (hard) makes the most suprising amount of rubbish fall out of the gaps in the keyboard!
Make sure you've switched it off first though
Steve
Steve
Smartassrobert_e_smart wrote:KriKy, that is a bit of Krap lucK Dean!
Good LucK
Tried air and banging to no avail, then i just went for it and pushed the k button hard and it is now functional, ish, so i can K whenever i need to now without cutting and pasting my K's out of someone elses post
If i reply to this thread later as a mute you will know it went badly!
