Alarm Problem !!!
harryjoe
Alarm Problem !!!
Post by harryjoe »
Hi all
My alarm has just gone off, and i cannot silence it !
Iv'e tried unlocking with the remote to no avail, ive also tried to silence it by turning the thingy under the bonnet also to no avail !!!, there is no sign of break in or anything,
Is there another way to shut it up ????
Thats pissed a few neighbours off :lol: :lol: :lol:
1997 Xantia 1.8i auto (sold)
1995 Clio Auto 32k mint cond
1997 Xantia Estate 1.9 td
Re: Alarm Problem !!!
Try turning the ignition on and pressing the alarm button. The key should silence it so suspect the alarm is faulty or has water in.
harryjoe
Post by harryjoe »
I'll try that in the moring now, it's a bit late , 'n' the certians are twitching in the close, , so ill give it a go when it's light :lol:
Iv'e disconnected the battery for now,
Iv'e even tried taking out no 27 fuse out, as per owners manual , but it still sounds
Keep you posted
Thanks for that
Nigel
Citroenesque
Post by Citroenesque »
You will need to recode the radio if you've disconnected the battery: the instructions were in the glove box, and you have the code.
This happened once with my other XM: you need to do as Dieselman says.
harryjoe
Post by harryjoe »
Thanks Phil.
Yes it's sitting very silent at ht he moment :lol: :lol:
Iv'e taken the origonal radio out and fitted a cd player, but yes thanks ,when it goes back in i'll have all the necessary info to code it,
I will try that in the morning, as i have to go to jolly Haywards Heath tomorrow , so hope it sorts it out ;)
harryjoe
Post by harryjoe »
Noooo !
That didn't work either :evil:
So drastic steps had to be taken, 'n' i cut the bloody wires to the siren !! :shock: :shock: ,bugger to get to !!, still all works ok , just no siren now !! :lol: :lol:
Because the front bumpeer will be coming off for a respray soon , i'll have a look at it then , and replace if necessary
minijet
Post by minijet »
harryjoe wrote:So drastic steps had to be taken, 'n' i cut the bloody wires to the siren
That is drastic :o
I've had alarm problems like this when the battery charge is a bit low or when I've had the battery out and reconnected it.
The alarm module is above the passenger footwell - black or grey box, about 6"x 4"x 1"- if you unplug it the alarm will stop.
harryjoe
Post by harryjoe »
minijet wrote:.
That is drastic :o
Ahhh , didn't know that one !! :oops: :oops: , i tried everything , dunno what set it off even, but the good news is that the bumper will be coming off very soon for a spray up. Soooo i'll fix it up then, either with the old one or a replacement ;)
