s1 v6 lhm pump strip
flez1966
Post by flez1966 »
Lez
flez1966
Re: s1 v6 lhm pump strip
Post by flez1966 »
moved
Lez
flez1966 wrote: the pistons have stuck in the closed positions, been sat in a damp shed...
Drop that in a container of diesel and leave it, the pistons will probably unstick and come out.
flez1966
Post by flez1966 »
But then i would have to weld the wobble plate back on....
its just old and worn, they dont last forever even running in oil, so i'll get a younger pump, found somewhere doing them cheap as power steering pumps :lol:
http://www.youtube.com/watch?v=CtKZ3e9b ... re=channel
http://www.youtube.com/watch?v=01L2jcep ... re=channel
before refitting the not-serviced pump i washed it out with petrol, lots, use a pipe and a jug and pump it through etc and if re-circulating use a cloth as a filter
you could do this on engine if careful.....
take note petrol wont lubricate and will inhibit lubrication, when washing pump by hand not an issue, at engine speeds, be very careful!
but, mine was flushed by hand, it rises faster than before and the low pressure warning at tickover has gone
Lez
