New hopefull daily!
Themasteryeti
Orga / RP numbers: 1993 XM Break 2.1TD RP5958
New hopefull daily!
Post by Themasteryeti »
Hey there, thought I'd introduce myself! I'm David and this is my new xm I got yesterday! Image bought it as a hopeful daily driver, seller originally gave me a bit of a list of problems it has like the locks being buggered and the low beams not working and the heater only works on full blast, all seemed like simple issues to fit, was quite far away so I got a company to deliver it.
All seemed good till it was driven off the trailer and hydraulic oil started pooling up on the floor by the front right hand side, which was to say the least bit heart wrenching and I'm yet to actually dive into where this is actually leaking from. But today's a new daily and I'm feeling a bit more hopeful! 😁
Julianw
Orga / RP numbers: 4937
Re: New hopefull daily!
Post by Julianw »
I think I'm right to say that hydraulic oil (LHM) leak will be from a low pressure return, as the suspension raised enough to be loaded and unloaded from the trailer? A leak on the low pressure return means an easier fix.
Your XM looks lovely! Please post about all your work on it
TigerHunter
Post by TigerHunter »
Congrats, mate!
The car's looking pretty good!
Have a look on the back of the hydraulic cylinder,. Theres a rubber draining house wich returns the LHM fluid to the canister.
When it breaks the leak is quite often mighty.
Citroen XM 2.0 Turbo CT Mk2 '97
Citroen AX 4x4
92 Xantia 1.6i
99 Xantia 1.9TD
00 Xantia 2.0 HDi break
04 C5 S1 2.0 HDi break
Themasteryeti
Julianw wrote: Thu Oct 02, 2025 12:47 pm I think I'm right to say that hydraulic oil (LHM) leak will be from a low pressure return, as the suspension raised enough to be loaded and unloaded from the trailer? A leak on the low pressure return means an easier fix.
It was a bit slow in raising the front and once I parked the car up and turned the engine off the front was nose down very quickly compared to the rear
But it's reassuring that this should (hopefully) be a easy fix! I'm completely new to these cars, so I wouldn't have a clue where to start but I am excited to learn on go 😁
Themasteryeti
TigerHunter wrote: Thu Oct 02, 2025 1:47 pm Congrats, mate!
It's definitely a bit rougher than it looks in pictures! But such a cool car, kids are well excited about it 😂
&& Is there any specific type of hose needed to replace this if that's what's broke?
TigerHunter
It's more than specific. It' s quite unique by design. I call it ' the alien'.
Can't show you more than a simple picture.
It's used on the Xantia's and C5's also . It's identical.
[http://www.dbk-dimitrov.com/dbk-dimitro ... xm-kb-015a][/url]
Citroen AX 4x4
92 Xantia 1.6i
99 Xantia 1.9TD
The rubber leak back hose is P# 95050399
The clip that retains it is P# 96127591
Consider this part a consumable item, so order a pair. If yours has the original stainless steel, click-clip, you can reuse it, if not order new clips, or a hose and clip as a kit.
The hoses normally perish and split at the top, where it pushes onto the steel return pipe. As a temporary measure, cut the hose off the steel pipe and push the remaining hose on.
Hose.
Original type clip.
A 2.1Td makes an excellent daily use car, especially useful in estate form. It looks like it's Sd trim level, any more info? Is it manual, or auto?
The Rp number printed on the left front door A pillar is important for technical information and parts. As the car was registered April 1993, it could have an early Hydractive-2 system, as opposed to Hydractive-1. The Rp number will tell all, as all Xm built post 11th February 1993 are Hydractive-2, Rp 5930 on.
There are some windscreen side trims available in the Sales/wants section of the forum.
My preference would be to re silver the bumper and trim inserts.
Be attentive to corrosion, it is the killer of an Xm, mechanically they are very robust and will cover very high mileages.
Don't be scared of Citroen hydraulics, they are very simple and generally reliable. There is nothing you cannot fix yourself, with basic tools, on an Xm.
I'm sure there will be trials and tribulations, but stick with it, a properly working Xm is a real treat to drive and ride in.
An overview of the hydraulics systems can be found here. viewtopic.php?f=13&t=10291
The low beams issue is likely to be the relay behind the right headlamp not making good contact in the holder.
Series 1 electrical diagrams can be found here viewtopic.php?f=8&t=10268
The Haynes ones are accurate for what they cover, as they are re-drawn Citroen diagrams.
Be aware; the Haynes wiring diagrams are for early Series1, the fusebox layout is for Series2.
Themasteryeti
Dieselman wrote: Fri Oct 03, 2025 6:49 am
Number in the door jam is 5958, it's a manual and I'm afraid that's all the information I have on it really! So I'm unsure of the difference between the hydractive1&2
& y'know I didn't even realize it didn't have the window trim 😂 I did find half of it in the boot! I'll have to have a ask about when I get paid 😁
Found the leak, its the pipe coming out of the strut, is this the same one you guys showed me? Image
& There is a bit of rot coming along the sills, but I've had to do a lot of welding on my other two cars so that doesn't bother me to much!
Also I seem to have a starting issue, I'll turn the key and I'll head a relay click, and I'll have to do this a few times before it starts to actually crank, then I'll have to crank for five seconds or so then stop then crank for another 5 and it'll fire up
The RP number means it will be Hydractive-2, which means it has 2 electrovalves to control the centre spheres, instead of one, with the spheres re-calibrated to give a slightly more compliant ride.
See post about adding extra diodes to Hydractive-2 suspension, to stop errant hard mode activation. viewtopic.php?f=13&t=9749&p=128197#p128197
The split pipe is indeed the one already discussed. It's easy to fit, just make note of which hole it pokes through in the bracket welded onto the strut.
For now just insert a pipe, or cut it off and re-attach it.
The starter circuit is very simple, the complete solenoid power passes through the Ign switch, so they can suffer, but it's worth checking battery connections and the starter/solenoid ones too.
These engines won't readily start without a full compliment of working glow-plugs, so check that too.
If you still experience delayed starting, probably with a cloud of smoke, suspect an air leak into the fuel pipes, or filter-head.
Rusty sills and jacking points is common on an Xm, but given you have a welder, and experience using spanners, you won't have any issues looking after the xm.
A 2.1td manual is very desirable, imho.
A further thought.
The vent fan only working n maximum speed is very likely to be the fan controller mounted on the fan unit. The variable speed is controlled as a result of the heating controller unit varying the fan speed via a pair of transistors apart from full speed, when a relay energises and sends full power to the fan motor.
Fan control module P# 6441 78.
