Good evening to everyone.
This is my first post on this forum but I joined awhile ago. I'm looking for some advice.
I have a 1998 series 2 citroen xm 2.1 vsx which I am slowly restoring.
I have been trying to find some rear subframe bushes and mounts as the ones on the car are too far gone. My question is has anyone got any for sale or know where to get some from or used something else. Any advice or help or recommendations would be very much appreciated.
Citroen xm rear subframe bushes.
Bubblehead-21
- XM newbie
- Orga / RP numbers: 1998 Citroen XM VSX 2.1TD CO 8094.
Julianw
- Orga / RP numbers: 4937
Re: Citroen xm rear subframe bushes.
I looked into this a while ago, and think there's some Metalcaucho items that fit. I'll try to find a link
Julianw
Looks like Chevronics are out of stock of them.
You might be able to pick one up from here:
https://citroessentials.com/product/950 ... roen-xm-i/
The original Citroen part number may be 96066441
Here's another possible source
http://www.autospares.eu/search.html?ar ... ce&smode=A
Hope this helps
Hope this helps
Julianw
PS these are details I dug up for my S1. Check to see if the part is different for an S2
P/no 5131 75 should be a set of two bushings to include a pair of each.
These are the same as Xantia bushings and appear to be readily available.
Bubblehead-21
- XM newbie
Thanks for your help with the subframe bushes. I've managed to get 1 mount so far so that's a start. Dieselman where did you see the xantia bushes, I've looked and everyone says they're out of stock. Once again thanks.
