Hello all,
Strangely, since renewing the battery, my blower has stopped working. Before taking the dash apart, is there anything I should check? Have replaced the under bonnet fuse but no joy.
Ta in advance x
99 XM 2.1td heater blower
Re: 99 XM 2.1td heater blower
Check the battery Gnd connection is good, the leads tend to suffer where they connect to the battery connector, due to bending the lead.
The fuse tends to suffer poor contact with the fuse holder, so don't assume that a good fuse is actually passing power.
Circuit diagram.
download/file.php?id=9711
Circuit diagram.
FrankHovis
- XM newbie
Thank you.
