New hopefull daily!
Re: New hopefull daily!
You could pull out the fuses, or unplug the Hydractive Ecu to force hard mode to be selected, which would be one test you need to perform anyway as part of the diagnostic process.
You can also disconnect each electrovalve return pipe and observe the flow of fluid...which should be a spurt as the valve changes state. Continuous flow indicates a leakage issue.
If you can't go under the car try disconnecting the return at the reservoir.
I don't have the fuse numbers, or return pipe info, to hand.
Themasteryeti
Orga / RP numbers: 1993 XM Break 2.1TD RP5958
Post by Themasteryeti »
Dieselman wrote: Tue Dec 23, 2025 6:45 am You could pull out the fuses, or unplug the Hydractive Ecu to force hard mode to be selected, which would be one test you need to perform anyway as part of the diagnostic process.
I have the fuse list in one of the handbooks! Image
Is the ecu the one under the plastic cover in the engine bay at the front on the driver's side?
F19 is the Ign supply to the Ecu, F34 is the Batt+ supply.
The Ecu is in the engine bay box, the one with two individual plugs, one black, one white.
TigerHunter
Post by TigerHunter »
Dieselman wrote: Tue Dec 23, 2025 6:45 am You can also disconnect each electrovalve return pipe and observe the flow of fluid...which should be a spurt as the valve changes state. Continuous flow indicates a leakage issue.
Wasn't his an S1 model?
S1 only has one HA valve with no return AFAIK
Citroen XM 2.0 Turbo CT Mk2 '97
Citroen AX 4x4
92 Xantia 1.6i
99 Xantia 1.9TD
00 Xantia 2.0 HDi break
04 C5 S1 2.0 HDi break
Themasteryeti
Dieselman wrote: Fri Dec 26, 2025 5:10 pm F19 is the Ign supply to the Ecu, F34 is the Batt+ supply.
Thanks! :D
Themasteryeti
TigerHunter wrote: Fri Dec 26, 2025 5:29 pm
It is a S1 with hydractive 2 if that helps!
Themasteryeti
Well I tried taking the fixes out and it didn't make any difference apart from the central locking obviously not working
You need to monitor the return flows to see where leakage is.
If there is no leakage the issue must be that the system is failing to make pressure, which assuming the 12mm relief bolt is tight, would be unusual unless there is an air leak at the pump suction pipe.
Themasteryeti
Dieselman wrote: Wed Dec 31, 2025 6:42 am You need to monitor the return flows to see where leakage is.
When it's not a cold icy day I'll have to try see the return flow then
&& I've never actually tried to see if the bolts tight but I'd be surprised if it isn't as the rear of the car lift normally still
&& I don't think there's an air leak, all pipes are tight on with no movements
Themasteryeti wrote: Wed Dec 31, 2025 4:52 pm && I've never actually tried to see if the bolts tight but I'd be surprised if it isn't as the rear of the car lift normally still
Unless the car is loaded, the front needs a lot more pressure than the rear, hence it shows any lack of pressure.
