Window regulators
R wood
Window regulators
Post by R wood »
Cable has gone ping (Again) on the drivers door window and rear drivers side is playing up.... Has anyone got parts or repair kit for either / both ?
its a 1998 Mk2 hatchback thanks in advance Richard
Re: Window regulators
Post by White Exec »
Was your replacement cable stainless, Richard?
Did the cable snap, or just detach/jump off?
R wood
Post by R wood »
It was a home made one out of a bicycle gear cable i will admit i have only just got the door panel off so it may have just jumped off, just a bit of a pain to do though or at least it was last time so wondered if anyone has a direct replacement
This is the stainless cable I have used. Extremely flexible and strong...
https://www.tecni.uk/1.5mm-7x19-316-Sta ... 04.000.015
Available by the metre, so you could buy enough to do all the windows without great expense.
No need for terminating nipples - just make a tight knot in the cable (put in a vise, and tug with pliers to tighten).
R wood
Post by R wood »
Thanks Chris can you give me a rough idea how much would be required to do all the windows ?
2m for each window should cover it.
10m all in to be safe.
R wood
Post by R wood »
Righto :)
