Wanted power steering pump 92 XM
Redpepsi31
XM newbie
Post by Redpepsi31 »
As above power steering pump required for my 92 XM if anybody has one in good working order please let me know.
Brent
Re: Wanted power steering pump 92 XM
Post by Peter.N. »
Presumably its the hydraulic pump you need, it doesn't have a seperate steering pump. Are you sure the pump is faulty because it also supplies the suspension and brakes. If it has a section fail the steering will feel 'notchy' when you turn it. Does it have a part number on it? If you can post it maybe someone can find you one, I might possibly have one here.
