For Sale or Breaking: Citroen XM 2.5TD Hatchback
EathanR
Breaking this XM. 2.5TD, won't start due to headgasket. In the interior everything I've tested works. All prices will be compared to eBay or similar and lowered. Postage available worldwide or collection from Telford, Shropshire.
Items sold -
Drivers door mirror
Towing eye covers
Expansion tank and mounting bracket
Dash top piece
Driver's door card
The screen on the left of dash switch panel (tells you the doors are open etc)
Vents on end of dashboard
Various plastic pieces from inside the interior
Passenger side head light
Scuttle panel end caps
Mounting brackets for ^^
Front grille mounting bolts
Front door speakers
Headlight washers and piping
Windscreen washers
Lid of air filter box
Items sold -
Drivers door mirror
Towing eye covers
Dash top piece
Driver's door card
Front door speakers
Windscreen washers
Rousayboy
Re: For Sale or Breaking: Citroen XM 2.5TD Hatchback
Hi could do with trim above windscreen on drivers side? Also original radio cass' and a hubcap or 2...? Thx Jon
XM car and XM estate top of windscreen trim are different and not same width or fixing so cannot be swapped.
For cars there is a standard Ford van top trim that all good screen fitters hold.
XM estate top trim unobtainium, been lots of requests in recent years, none reported as successfully met.
Rousayboy
Thx sounds typically french then...the hunt continues.....cheers jpn
Timcol
- Orga / RP numbers: RP 7183
Series 2
2.0 16v Sx
1997
Any chance of nearside front door lock (motor) pm with price
Thanks Tim
Thanks Tim
I'd like the coolant expansion/header tank, and the aluminium bracket behind it, please.
Please PM me with a price, Eathan.
DownUnderXM
- Orga / RP numbers: RP 8603
Sorry for noob questions - is the car a Series II, and is the dashboard black?
If so, would I be able to buy the long trim part that sits at the front of the dash, in front of the demisting vents? Would I have to get the windscreen removed to fit it?
It would of course have to be shipped to Australia - much as I would like to come and collect it in person!
Cheers
Alec
Cheers
Alec
For info.DownUnderXM wrote: ↑Mon Apr 27, 2020 12:03 amSorry for noob questions - is the car a Series II, and is the dashboard black.
All 2.5td are Series 2 and all series 2 have Hurricane Grey interior plastics.
Only '89-'91 Xm have black interior plastics.
Our S2 interior plastics are black, Will.
I suspect they are Hurricane Grey.
If you put a piece next to an early S1 interior plastic, you would see the difference, it's subtle...but there.
