xm 2ltr turbo s1 sei
demario
hi can anybody with pin out diagram for bosch engine ecu many thanks
Re: xm 2ltr turbo s1 sei
Pin-out details are included in this document...
viewtopic.php?f=13&t=7592&start=70#p115087
See Engine, petrol 2.0
Covers the rest of the car, too.
The PDF can be downloaded and printed.
Keep us informed as to how you are getting on with your fixes, as we can probably help you out further as you go.
demario
Hi thanks for your help i need series 1 ecu pin outs not s2 which i have im trying to locate inertia switch wiring or switch location many thanks
There isn't an inertia switch on a Series 1 car.demario wrote: Mon Mar 16, 2020 9:18 am Hi thanks for your help i need series 1 ecu pin outs not s2 which i have im trying to locate inertia switch wiring or switch location many thanks
What exactly is the problem?
demario
Hi fuel pump not switched on from 807 relay pin 3 from ecu not connected to ground if i connect a wire to pin 3 and ground pump works and engine fires up i fitted s/h ecu still the same fault
Demario, if you can post your RP number, I'll dig out the correct circuit diagram for your injection ECU.
I think the attached should contain the correct diagrams for you.
The diagram for engine codes RFZ using Motronic 3.1 shows the fuel pump to be controlled by relay 816, which is fed +12v from relay 807 receiving power from the Ign switch and Gnd.
Relay 816 is controlled by the ECU Pin 20 going to Gnd.
Firstly, check you have all the appropriate power feeds and Gnd for the ECU to function, then read the fault codes and go from there.
Obviously the ignition and fuel side of the system work, as you can force it to run.
demario
hi rp no 5936 runs with bosch ecu 0 262 200 219 96 182 194 80
Thanks for the RP number. The circuits I have here don't go back far enough, so I hopefully Will's (Dieselman's) document will help.
