Wanted: Crank or engine
Zef
XM newbie
Post by Zef »
I'm in urgent need for a crank from a H reg XM 2.0 petrol. That or a good engine I can rob the crank out of. Sadly the one we have is 12 thou bent and no2 big end is 24 thou knocked out. I'd even settle for info on crank compatibility from other cars.
Many thanks for any help you can give.
Re: Wanted: Crank or engine
This is listed as an XU10J crankshaft but it is from an XU10J4, yours is an XU10J2, I think the cranks are the Same but you may have to compare specs with the seller
https://www.ebay.co.uk/itm/RECONDITION- ... ect=mobile
That should be good to use.
The later p/n for an 8v atmo, turbo and 16v atmo it 0501.G1.
As John has said, it wil need appropriate shells.
There shouldn't be any shortage of 2.0i-16v engines knocking about if an 8v is too difficult to source.
Zef
XM newbie
Post by Zef »
Thanks guys. I've spoken to Bradford grinders before. Small world. I'll give them a ring tomorrow. Brilliant if it works out.
