newbe
mrhappy
XM newbie
Orga / RP numbers: citroen xm sx auto
newbe
Post by mrhappy » Thu May 30, 2019 10:02 pm
hi all
just purchased a xm sx auto and need help getting a sunroof plastic gear :D
Saraphi
Orga / RP numbers: 6834
Re: newbe
Post by Saraphi » Sun Jun 02, 2019 7:49 am
Welcome - where are you located? I'm sure that someone who knows about these things will be along to help. Mean while keep looking - don't just seal off that sunroof!
1995 XM S2 2.0i 16v - but with lots if Y3 bits
1995 Xantia 2.0 Exclusive
Re: newbe
Post by citroenxm » Mon Jun 03, 2019 12:26 pm
What precisely are you after. Not sure what you mean by su roof plastic gear?
mrhappy
XM newbie
Re: newbe
Post by mrhappy » Mon Jun 10, 2019 1:57 pm
just purchased a citroen xm I am located in the wigan Lancashire area
long story short I went to buy a pie and got a xm . well it made sence to me anyway
but I cant open the sun roof. the motor runs so I think the cogs / gears are stripped they seem to be plastic / one white one black
it seems a shame not to fix it
mrhappy
XM newbie
Re: newbe
Post by mrhappy » Mon Jun 10, 2019 2:04 pm
located leigh lancs no leaks yet
mrhappy
XM newbie
Re: newbe
Post by mrhappy » Mon Jun 10, 2019 2:05 pm
motor runs but nothing opens
ul9601
Orga / RP numbers: don't have any
Re: newbe
Post by ul9601 » Mon Jun 10, 2019 6:58 pm
Have you taken the motor/gearbox off and opened it up?
There are a number of gears - if anything it would be the worm gear/cable is the one that's stuffed.
'91 carb'd 2.0 manual
mrhappy
XM newbie
Re: newbe
Post by mrhappy » Mon Jun 10, 2019 8:20 pm
I have not stripped the motor but
I have taken the light cover off and can see two plastic gears and they are slipping but no movement from the sunroof
Re: newbe
Post by Dieselman » Mon Jun 10, 2019 9:27 pm
the usual reaon the gears strip is because the cables have seized.
It's possible the motor clutch has been disengaged to keep the roof closed.
The rod projecting from the gear spindle moves the gear on an eccentric, thus engages, or disengages it as required.
mrhappy
XM newbie
Re: newbe
Post by mrhappy » Wed Jun 12, 2019 8:03 pm
I will wait for the rain to stop before I strip it . thanks for the info
