Stock reduction needed
House purchase will soon mean that will NEED to leave the farm of where for the last 13 years I built up a large stock of Xm as well as some xantia parts..
Offering xantia parts seem to fall on deaf ears so there's only one place for it to go..
So.. Of course I've two Xm. My 24v S1 and a 2.1td auto left. I have a 24v twin to my own less an engine. This car is a likely donar for my own so likely to keep on parts and dispose of the main shell. However out of it came a leather set with ALL seat heaters bar the Drivers seat base in working order. I may fit this to my own 24v.
However. I will not have space for all the stuff I have. A trim down will be needed..
Here's the yard to date.. Sheds next.. Soo if you are in need of things send me some lists so I can sort stuff out. Otherwise things will go the same way as xantias stuff.
My shed size to reduce to will be something along the lines of a 13ft x 10ft or so size
- onza100
Re: Stock reduction needed
Don't forget my list please mate. I'll have a think if there is anything else. I expect me and iain will visit again at some point
Degens
Hi,
do you have a brake pipe for the Blue XM you once repaired, and maybe a left bumper bracket (it appears the previous owners had cut it off). Also, if you have left and right lamp spray caps that would be great. The blue one is still going, though had a bump in the back (as I posted on the forum) but is at this very moment in repair!! and I hope to be able to show it at the 100-year Citroen event in Coventry, together with my new older white Citroen XM Turbo.
Thanks again for keeping my car in the road, now already 4 years ago!!
Best wishes,
Hans
Best wishes,
Hans
Hi hans which pipe? Front.. Rear.. Passenger side.. Drivers side??
Thanks. Glad to hear it's still going well.
Degens
Thanks,
I just checked the MOT and it is the brake pipe at the offside front.
Best wishes,
Hans
Best wishes,
Hans
Metal pipe or the flex hose connected to the caliper?
Degens
It must be the metal pipe as it was corroded.
OK. See what I can find.
Degens
Thanks
Woodie
Hi dont suppose in your bin of stuff you have an exclusive badge a good late foglamp (nearside) with reflector intact or a entire late series front bumper complete with headlight washer caps and foglights (a very long shot i know)... thanks Richard
Richard
