air con compressor wanted urgently
ststech1973
Orga / RP numbers: xm 2.1td sed 1992 rp 5566
Post by ststech1973 » Fri Jul 06, 2018 6:08 pm
i have a 2000 v6 24v series 2
i need an ac compressor its like the ones fitted to xantias the supply/discharge ports are on the side next to each other pipes held in with a clamp.
thanks in advance Simon
2012 ds4 d style 1.6 hdi 110 silver
2007 c5 2.0i 16v exclusive auto (sorn)
2007 c6 2.7hdi exclusive mauritius blue (sold)
2007 c4gp 2.0 hdi egs exclusive
Re: air con compressor wanted urgently
Post by xantia_v6 » Fri Jul 06, 2018 7:22 pm
You might ask Stickyfinger on FCF, he has broken a couple Xantia V6s, and is in your part of the world.
How has yours failed? I have never had a problem with one (and have owned 5 cars with this engine).
ststech1973
Post by ststech1973 » Sat Jul 07, 2018 7:57 am
the clutch has packed up it made an awful noise when i engaged it for a second or two then when i did it again yesterday it didnt engage and is open circuit
the clutch spins freely enough though but the clutch solenoid is open circuit.
Post by White Exec » Sat Jul 07, 2018 9:15 am
Might the clutch unit be available as a separate part?
Post by xantia_v6 » Sun Jul 08, 2018 2:57 pm
ststech1973 wrote:the clutch has packed up it made an awful noise when i engaged it for a second or two then when i did it again yesterday it didnt engage and is open circuit
Did you measure for continuity at the clutch itself, or are you relying on the Lexia diagnosis? The Lexia will report an open circuit clutch if the refrigerant pressure switch has tripped.
ststech1973
Post by ststech1973 » Sat Jul 21, 2018 2:53 pm
checked clutch resistance and it is open circuit for sure!
Post by White Exec » Sat Jul 21, 2018 4:31 pm
Exchange clutch?
