WANTED URGENTLY XM2.1TD LOWER SPEEDO CABLE
ststech1973
Orga / RP numbers: xm 2.1td sed 1992 rp 5566
Post by ststech1973 » Mon Apr 30, 2018 9:31 pm
Wanted urgently!
Lower speedo drive cable for Xm 2.1td
It screws into the bottom of the speed sensor located by lhm tank and the upper screws in other side of it
As I inadvertently snapped the plastic end of the Lower cable
2012 ds4 d style 1.6 hdi 110 silver
2007 c5 2.0i 16v exclusive auto (sorn)
2007 c6 2.7hdi exclusive mauritius blue (sold)
2007 c4gp 2.0 hdi egs exclusive
Re: WANTED URGENTLY XM2.1TD LOWER SPEEDO CABLE
Post by Dieselman » Tue May 01, 2018 11:55 am
I may have one, not sure, but in the meantime just wire and glue the original back to gather.
Nylon is a difficult plastic to glue, but if you reinforce the joint with wire wrapped into both sections and then tie both wire loops together, then epoxy glue, it will never fail again.
