Hi All,
Does anyone have a driver's side front door check strap? Will - I have messaged you about this, as I think you said you had one.
Got my central locking working on the key, but not on the remote fob. I believe there is a solenoid in the front driver's side door that may be faulty? If so, does anyone have one?
Happy to pay whatever + p&p.
Thanks in advance,
Lee
Citroen XM 2.1TD 1994 Mk2
Check strap +
Lwdajo
Check strap +
Lwdajo
Re: Check strap +
Strangely the door solenoid has started to work, so the central locking is now working on the the remote. I didn't do anything to make it work.
I still need the check strap if anyone can help.
Thanks,
Lee
Thanks,
Lee
Re: Check strap +
Hi Lee,
I do have a check-strap, just been too busy to contact you.
Lwdajo
Re: Check strap +
Hi Will,
If you can let me know when you are available, I'd appreciate it. I could visit you after work, if it helps.
Thanks,
Lee
Thanks,
Lee
