Another early car appears!!
Post by MTXM » Fri Jan 19, 2018 11:51 am
I just spotted this on the Bay that could be a nice project for someone!
https://www.ebay.co.uk/itm/Citroen-xm-2 ... 2914169931" onclick="window.open(this.href);return false;
The listing is fairly comprehensive and the buyer is open to offers. I note the reg. is very similar to press cars of the period with a Reading area code, so probably first owned by Citroen UK. The rear plate and window sticker show 'Citroen Olds', Puddletown, which seems to be in Dorset. There is a red badge steering wheel although the sun-roof is factory fitted.
It also happens to be located fairly close to me in North Suffolk and I could probably find time to call and assess if required.
With regards,
Matthew T.
Re: Another early car appears!! H627 GDP
Post by Dieselman » Fri Jan 19, 2018 1:14 pm
I love early cars, but the 2.0i engine puts me off a bit. Overall it looks ok, only general tidying. The MOT history is pretty revealing though. Been a fair bit of welding required for the last several MOT's. :|
Post by MTXM » Fri Jan 19, 2018 1:39 pm
That is helpful advice Will and based on the info displayed sadly it may be best suited as a parts car! With regards, Matthew T.
H627GDP
CITROEN XM
Check another vehicle
Colour
Blue
Fuel type
Petrol
Date registered
23 August 1990
MOT valid until
23 May 2018
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All
MOT History
Mileage recorded at test, parts failed or had minor problems
Date tested
24 May 2017
PASS
Mileage
135,015 miles
MOT test number
3246 3855 5216
Test location
unavailable until further notice
Expiry date
23 May 2018
Advisory notice item(s)
Rear Sub-frame repaired, but not inappropriately (2.4.A.2)
What are advisories?
Date tested
17 May 2017
FAIL
Mileage
134,997 miles
MOT test number
5668 5608 7742
Test location
Reason(s) for failure
Registration plate lamp not working (1.1.C.1d)
Offside Front position lamp(s) insecure (1.1.A.3a)
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Front registration plate deteriorated (6.3.1d)
Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Offside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Rear Fluid suspension unit leaking (2.4.D.2)
What are failures and advisories?
Date tested
27 June 2016
FAIL
Mileage
134,973 miles
MOT test number
2111 7123 3340
Test location
Nearside Registration plate lamp not working (1.1.C.1d)
Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Track rod end ball joint has excessive play (2.2.B.1f)
Offside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Offside Rear Tyre has ply or cords exposed (4.1.D.1b)
Horn not working (1.6.2a)
Nearside Front Seat belt anchorage prescribed area is corroded but not considered excessive (5.2.6)
Nearside Rear Subframe mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
Date tested
1 July 2015
PASS
Mileage
133,197 miles
MOT test number
2082 6218 5455
Test location
Expiry date
23 July 2016
Offside Front Seat belt anchorage prescribed area is corroded but not considered excessive (5.2.6)
Offside Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Nearside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Nearside Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
Offside Rear Subframe mounting prescribed area is corroded but not considered excessive (2.4.A.3)
o/s/r tyre worn on inner edge
o/s/f sill corrosion
Date tested
29 June 2015
FAIL
Mileage
133,194 miles
MOT test number
3997 9088 5192
Test location
Nearside Front Suspension arm has excessive play in a pin/bush (2.4.G.2)
Nearside Front Steering rack gaiter split (2.2.D.2d)
Nearside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Offside Windscreen washer provides insufficient washer liquid (8.2.3)
Nearside Rear Sub-frame corroded and seriously weakened (2.4.G.1)
Date tested
2 July 2014
PASS
Mileage
130,552 miles
MOT test number
2365 2358 4190
Test location
Expiry date
23 July 2015
Offside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
Date tested
1 July 2014
FAIL
Mileage
130,543 miles
MOT test number
5864 4298 4134
Test location
Offside Front Tyre has a lump, caused by separation or partial failure of its structure (4.1.D.1b)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Date tested
11 July 2013
PASS
Mileage
127,776 miles
MOT test number
3774 5239 3128
Test location
Expiry date
23 July 2014
Date tested
3 July 2013
FAIL
Mileage
127,731 miles
MOT test number
4894 4438 3155
Test location
Offside Headlamp excessively damaged so that the light output is severely reduced (1.7.5a)
Offside Front Steering rack gaiter split (2.2.D.2d)
Front Fluid suspension unit leaking (2.4.D.2)
Nearside Rear Radius arm has excessive play in a pin/bearing (2.4.G.2)
Nearside Rear Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
Nearside front parking brake recording little or no effort (3.7.B.6a)
Date tested
3 July 2012
PASS
Mileage
123,471 miles
MOT test number
6857 7578 2140
Test location
Expiry date
23 July 2013
Front Sub-frame corroded but not seriously weakened (2.4.G.1)
o/s/f tyre cracking on side walls
o/s/f sill corrosion not structural
Date tested
2 July 2012
FAIL
Mileage
123,464 miles
MOT test number
7985 6448 2128
Test location
Nearside Front Side repeater not working (1.4.A.2c)
Nearside Front Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
Nearside Windscreen washer provides insufficient washer liquid (8.2.3)
Date tested
22 July 2011
PASS
Mileage
120,659 miles
MOT test number
5552 8390 1262
Test location
Expiry date
23 July 2012
n/s/f tyre cracking on side walls
Date tested
20 July 2011
FAIL
Mileage
120,656 miles
MOT test number
8281 0120 1210
Test location
Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front constant velocity joint gaiter split (2.5.C.1a)
Date tested
29 June 2010
PASS
Mileage
116,605 miles
MOT test number
7311 4018 0106
Test location
Expiry date
23 July 2011
Date tested
28 June 2010
FAIL
Mileage
116,602 miles
MOT test number
2716 1917 0105
Test location
Offside Front Body insecure and dangerous to other road users (6.1.B.1b)
Nearside Steering rack gaiter insecure (2.2.D.2d)
What are failures?
Date tested
17 July 2009
PASS
Mileage
112,360 miles
MOT test number
6002 7879 9149
Test location
Expiry date
23 July 2010
Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
N/s hand brake cable is in poor contition
Corrosion o//s/r inner sill
O/s/r sub frame mounting is rusty
Rear brake discs are worn
Date tested
13 July 2009
FAIL
Mileage
112,350 miles
MOT test number
5411 6479 9154
Test location
Offside Rear fog lamp not working (1.3.2b)
Offside Rear Sub-frame corroded and seriously weakened (2.4.G.1)
Offside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Offside Front Fluid suspension pipe leaking (2.4.D.2)
Date tested
1 July 2008
PASS
Mileage
109,803 miles
MOT test number
5909 1348 8124
Test location
Expiry date
23 July 2009
n/s/r tyre is perished in tread.
osf tyre pressure low
osf bumper loose
ns outer sill corroded
Date tested
30 June 2008
FAIL
Mileage
109,792 miles
MOT test number
2132 7278 8406
Test location
Offside Rear Tyre has a cut in excess of the requirements deep enough to reach the ply or cords (4.1.D.1a)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front Windscreen washer provides insufficient washer liquid (8.2.3)
Date tested
16 July 2007
PASS
Mileage
107,272 miles
MOT test number
6607 8719 7111
Test location
Expiry date
23 July 2008
Both sill are rusty.
both rear tyres are in poor condition.
Date tested
10 July 2006
PASS
Mileage
104,566 miles
MOT test number
1608 0169 6133
Test location
Expiry date
23 July 2007
suspension stiff †fluid leaks from suspension components †rear tyre walls are perished †handbrake cable outer covers in poor condition †
sageman
Post by sageman » Fri Jan 19, 2018 9:14 pm
this has been for sale since the summer i went and looked when he first put it up
never owned an xm before but i think theres something very wrong with the suspention seems very hard also diddnt look to me like the front went to the right level looked as though it should be lower but perhaps thats just me
seats are fine although dash is a little tired somethings been stuck to it in the past and left a mess
exterior also tired more-so than pictures reveal
engine seemed fine
i only realy went to see it to find out what the ride in these is like having never been in one before but this one felt no better than my gti-6
i am looking for an xm but want a later one with digital climate control cruse control etc
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
Post by Dieselman » Sat Jan 20, 2018 12:30 pm
Hard ride and incorrect ride height are generally easily sorted. Hard ride on an early car is normally the spheres are flat. There could be a problem with the Hydractive system, which defaults to hard if disabled, or engine off, but that isn't particularly likely on an early car with H1 hydractive.
The ride height is controlled by adjusting the clamp on the anti-roll bar. If cars have been sitting for a long time, they generally ride high as the linkage rod deforms slightly.
Early XM ride can seem a bit brittle at low speeds, but as speed increases they get more compliant. Later XM use larger corner spheres with more relaxed damping to counter this. Technically, one could tune XM suspension to personal preference by selecting different spheres and making adjustments to the damping orifaces. Different brands of spheres make cars ride better, or worse.
Pretty well all early cars should now be regarded as project cars. If it's not rotten, it's worth saving, there are so few left.
Regarding the dashboard, my preference is for the rotary dials, over the push buttons.
Post by citroenxm » Sat Jan 20, 2018 8:37 pm
This is its second time round listed on the evil bay..
sageman
Post by sageman » Sun Jan 21, 2018 12:10 am
[quote="Dieselman"
Regarding the dashboard, my preference is for the rotary dials, over the push buttons.[/quote]
any particular reason
is good to know suspension might not be as bad as it seemed although i would still want a later car i think did early ones have cruse control and digital climate control ?
1976 Reliant kitten
Post by Dean » Sun Jan 21, 2018 1:05 am
yep early cars of a higher spec had digital climate, the cruise was engine and spec dependant.
Post by Dieselman » Sun Jan 21, 2018 1:42 pm
sageman wrote:
Dieselman wrote: Regarding the dashboard, my preference is for the rotary dials, over the push buttons.
Rotary dials suit the dashboard better and allow finer control of air direction. Appearance is the real preference.
I've looked at the pictures again and it is riding high at the front...just needs adjustment. The disk stuck to the dash is for a phone mount. It's not much work to swap that part of the dashboard, it screws on.
The overall condition is about what a standard 27 year old Xm is like. No reason it couldn't be either a daily driver, or a project to turn into a nice, early car.
Post by citroenxm » Sun Jan 21, 2018 4:19 pm
Dean wrote:yep early cars of a higher spec had digital climate, the cruise was engine and spec dependant.
No quite Dean.. no XM had cruise from 89 to 92... cruise was not offered at all untill the main lights switch was moved from the roatry switch to the light stalk switch... as the roatry switch is where the cruise leaver was then fitted....
