Estate capacity - carry some interior doors?
jonhopper
Post by jonhopper » Thu Dec 21, 2017 4:20 pm
About to collect an XM estate after 15 years or so without an XM...and last was a Saloon.
Over the weekend I need to collect 5 interior doors - standard size - 6'6" tall and 30" wide... 198cm tall..
Will these fit in the back?
thanks
Jon
Cambridge
Re: Estate capacity - carry some interior doors?
Post by Dieselman » Thu Dec 21, 2017 6:19 pm
Should do with just the seats folded, but definitely will with the rear seat base removed. It is held in by a pair of rubber blocks, one in each hinge.
Post by xmexclusive » Thu Dec 21, 2017 11:56 pm
If needed run the front passenger seat as far forward as it will go.
With the front passenger seat full forward and laid flat you can get 10 ft (3m) lengths of wood into a XM car.
The estate is the same chassis with an extra 9 inches to the inside of the bottom of the tailgate.
The tailgate is much steeper so far more extra space higher up than a car.
Have shifted larger doors inside an XM estate but a while ago.
Southerneruk
Post by Southerneruk » Thu Dec 28, 2017 12:25 pm
All ways fit on the roof.
