Diagnostic connecting lead
hank123
Post by hank123 »
Hi, I need a diagnostic connecting lead for my 94 XM. I have a problem with the ABS. Can anyone help please?
Re: Diagnostic connecting lead
Post by MTXM »
Tell us where you are Hank and hopefully someone can help! Regards, Matthew T.
hank123
Post by hank123 »
Hi Matthew, thanks for your post. I live in Haverhill near Cambridge. Regards, Gary.
Do you need a lead to connect to a laptop, or are you just looking to read codes.
If the latter, a simple Blink Code reader will suffice. You can probe the connector and read the codes.
hank123
Post by hank123 »
Hi dieselman. Thanks for your post. I just need to solve a ABS problem. If a blink code reader will do the job, great. Where can I buy one, and how much do they cost please.
Just make one out of a few parts. you need a push to make switch, an LED, a resistor, a couple of bits of wire, two battery connection clips and a pin connector.
ststech1973
Orga / RP numbers: xm 2.1td sed 1992 rp 5566
Post by ststech1973 »
i have built my own blink code reader that will display the codes numerical, I will upload the circuit i designed and built plus photos probably after xmas,
It works a treat :).
All parts available from maplin,i plan to build the pcb as currently on veroboard!
2012 ds4 d style 1.6 hdi 110 silver
2007 c5 2.0i 16v exclusive auto (sorn)
2007 c6 2.7hdi exclusive mauritius blue (sold)
2007 c4gp 2.0 hdi egs exclusive
