Wanted : n/s/r suspension pipe
xm24v
wanted urgently, n/s/r suspension pipe, the 16mm diameter one with the 17mm nuts on either end and the rubber flexible in the middle.
Mine has corroded through and I need my car for work so need one asap.
I've tried every hydraulics place in the northwest and no-one can either repair mine or make up a new one so a good used pipe appears to be my only option.
Thanks.
Thanks.
1991 XM 24V S1
1991 Renault 25 2.9i Baccara
1994 Renault Safrane 3.0i RXE
1984 Talbot Tagora SX 2.6
1980 Renault 30TX auto phase 1
1980 Renault 30TX manual phase 1
1982 Renault 5 Gordini Turbo
Re: Wanted : n/s/r suspension pipe
Try Paul (Citroen XM).
Failing that Frederick in France (ask MTXM for contact details).
Ebay item 401309125911, this seller has both V6 pipes on ebay and posts to UK.
I have found him reliable.
Another option for the pipe would be Mark at Edwards & Son of Billericay, who would definitely have the part available and is extremely efficient and reliable. Regards, Matthew T.
sdelasal
This is bad news!, "I've tried every hydraulics place in the northwest and no-one can either repair mine or make up a new one so a good used pipe appears to be my only option. " Have you tried pirtek, i've heard good things! for example; http://www.pirtek.co.uk/service-centres/north-west" onclick="window.open(this.href);return false;
- jamescarruthers
Re: Pirtek: I hear you must not mention that it is for a road vehicle though! Start with a little white lie and you may have some luck. You could say you need it to be compatible with MIL-H-5606, another mineral hydraulic fluid (e.g. Aeroshell 41).
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Previous XMs:
H656 BKJ XM 2.1 SED
Theres two sort.. early ones had an 3.5mm T junction for a feed back to the front.. later cars didnt.. i think ive got one darren needs but is stuck on a subrame as is corroded at the strut end..
Darren needs the one with the return
Darren i can have a check again tomorrow for you
xm24v
Thanks for the leads guys, The seller on eBay currently only has the o/s/r pipe listed so I've emailed and asked if they have the one for the left.
Pirtek couldn't help, apparently they can't do the double swage on either end.
I'll try Edward and sons tomorrow and see if they have one.
I'll get a pipe one way or t'other.
Thanks again for the help.
1991 XM 24V S1
xm24v
Thanks Paul, mine was seized at the cylinder end and ended up shearing the pipe when I got it undone. No biggie as the pipe was buggered anyway. Check out the pinhole, it lost 5 litres of lhm through that in seconds.....
1991 XM 24V S1
Sometimes you need a blast of heat to undo those rusted on banjo bolts, there is no other way. If, after using penetrating oil, it starts to twist the pipe at all...STOP...and apply a blowlamp to the bolt before continuing.
If really stuck, and I know it's a long way away, try SGS at Dunsfold.
Used to be Shalford Green Garage, but moved to Dunsfold (Surrey) and expanded.
Long-time Citroen specialist.
