WANTED: S2 2.0 turbo petrol fuel rail
SilverXM
Hello- looking for a fuel injector rail for a 2000 2.0 petrol turbo- part number 9628802880. Can anyone help?
Re: WANTED: S2 2.0 turbo petrol fuel rail
Is that an alloy manifold?
The manifold will be Alloy, the fuel rail will be steel painted black or possibly plastic but either the plastic or metal one will fit, as does the fuel rail from a normally aspirated 8v engine.
Riverhead
I've one from a 1994 2.0 turbo.Dean wrote:The manifold will be Alloy, the fuel rail will be steel painted black or possibly plastic but either the plastic or metal one will fit, as does the fuel rail from a normally aspirated 8v engine.
Not sure if it's the same.
Should be
Sent from my iPhone using Tapatalk
SilverXM
Hi Riverhead- I've tried sending you a PM but not sure it worked (I'm new and still finding my way around!) but are you able to send me a picture and I'll see if it corresponds?
It will fit, there was only the one fitment for the XU10 engine, the only thing you really need to watch is the fuel pressure regulator, the later car has the cheap, newer style 'in rail' regulator and the early non turbo cars have an expensive external type regulator.
I think all TCT engines got the in rail regulator with only the NA 8v having the external regulator.
