So its been almost a year since I bought Jonathan_dyane's old XM and brought it over to Belfast.
I am reasonably active on Autoshite.com but thought it only fair to update over here as well, especially as I have had some help with you guys - notably being supplied a decent used coolant pipe from "Citroenxm", without this I would have struggled.
Its a lot of faffing to copy all the stuff over, and I'm lazy so link to the collection thread here http://autoshite.com/topic/25660-my-fle ... =carashite" onclick="window.open(this.href);return false;
And I'll do an "executive summary" (its an executive car after all!) on the next post.....
My s1 diesel
- raynoon
- Orga / RP numbers: 6043
Re: My s1 diesel
Clicked the link.... and WOW! My (ex) KVG in Practical Classics... I sold her a few months after that article was published..
Looking forward to reading your next post.
Mike_NI
Re: My s1 diesel
So in anticipation of collecting the citroen, I bought some essential reading
This was my first view of the beast
On to fixing things. The most important bit was the coolant pipe. Access wasnt great. Many parts were removed
The culprit
Off the car....yay....but where is the rest of it?
Part of the pipe stayed in the thermostat housing. This was a pain but gently cutting a slit along its length allowed me to prise the remains up and out.
Next was fitting my new rad, bought on amazon for £12. The one in the car wasnt leaking but was from the wrong model and didnt have a boss for the temperature sensor. The fans had been hard wired to run constantly.
Bit of a bodge required here
Then the fans wouldnt work......traced this to intermittent fault with the relays, all good after that sorted...
Next on the list was replacing the dodgy high pressure pump. It was rattling like a bastard and the steering was terrible. I had by chance bought a cheap one on ebay (£30!) for parts but thought I would give it a try before attempting to strip the old one
It only worked! Took an age to bleed the LHM but now we have silky smooth steering and suspension that raises promptly on startup.
After all that and a couple of tyres she passed her first Northern Irish MOT.
More to follow.....
Sent from my SM-A510F using Tapatalk
The culprit
More to follow.....
Mike_NI
Re: My s1 diesel
So recently I done some towing, a mate bought an old caravan and has no towbar, so I offered to do some collectioning. Of course it rained. Have a video:
https://youtu.be/poZcNgMK7XE" onclick="window.open(this.href);return false;
This proved the XM is ready to tow, bar a bit of a hot oil smell during one climb the temperature stayed stable and no oil, coolant or LHM was used.
We are going to drag our own terrible old caravan out of storage for an overnight this weekend. In preparation ive bought a shonky old CD player off ebay. So far I have removed the tape player and discovered MANY WIRES
What is this?
Two antenna cables?
Must consult the HBOL....
What is this?
Two antenna cables?
Mike_NI
Re: My s1 diesel
Recent adventures in caravan collectioning reminded me I really needed to sort my own van out. But before all that some battery bollocks - the XM does sit for long periods and I'm lazy so only charge the battery when I remember. To compound things something deep in the bowels of its French wiring is slowly draining the battery.
Rather than trace the drain I just bought an isolating terminal switch.
HOWEVER the negative terminal was bodged onto the existing battery as it appears to be too big. Meaning it slips off the isolation jobbie when fully tightened. Bugger.
So I just put it back the way it was. At some point I'll get a suitable terminal.
And onwards to caravan storage. God I'm bringing down the tone aren't I?
Its a Swift Corvette of 1989 vintage so period correct for the car. It was also bloody filthy
"We advise the public not to approach this outfit"
Anyways a good couple of hours washing the bastard thing and it looks OK again. I even managed an EBAY special photo of its magnificence
I'm not sure either
Still much to do. Some twat nicked my wheel trims. Fuck knows why, they were mismatched cracked cheap ass aftermarket specials. Unless someone was just really offended by them and binned them for me. Anyhow I plan on painting my phat rimz. Unsure on colour. Perhaps white, most likely resale silver but I have had a stirring for a nice bottle green to match the side stripes....
Anyway its back in storage for now. Isnt she a looker etc etc
And another spaff worthy picture of the XM for shits and giggles
Theres some really fucked looking caravans in that storage place. This one isnt even that old.
I'm not sure either
Re: My s1 diesel
Some great pix and details there, Mike.
Bargain radiator, and Valeo too.
Liked the AS link to Citroen-Musik!
We towed a Swift Corniche for a good few years with our 2.5, all over UK and mainland Europe. What better to tow with?
That battery terminal looks dire, especially on a diesel: treat yourself to a brass pair, and dump the lead (Pb) lumps.
You should be able to track down the current drain - check out Gabor's list of typical XM quiescent currents here (see p.28):
viewtopic.php?f=13&t=7592&start=20#p104621.
Re: My s1 diesel
The twin aireal cables were dropped from s2 cars.. not sure why s1 had them.. the round 5 pin din is for the steering wheel radio controls.. pry out the sterring wheel boss and see if theres wires behind there if theres no button on your wheel centre..
Re: My s1 diesel
I have never seen a car with the twin-aerial cables, but I know the theory.citroenxm wrote:The twin aireal cables were dropped from s2 cars.. not sure why s1 had them..
It is practically impossible to make an aerial cable that works efficiently for both FM (VHF) signals and AM (MW/LW) signals, due to the change in antenna impedance with frequency. The antenna cables fitted to most cars now are more optimised for VHF, so the MW/LW performance is lousy. Having 2 cables with a passive diplexer at the antenna base allows everything to be optimised.
Xantia Exclusives (and I presume the S2 XM) solved the problem in a different way, by having a single cable optimised for FM, but adding an active preamplifier at the antenna base to boost the LW/MW signals.
Mike_NI
Re: My s1 diesel
I thought it prudent to leave a list of to-do items here. Its by no means exhaustive and will get added to
Stop sunroof leaking. When I bought the car the sunroof was sealed with tape, this kept the car waterproof but I wanted to be able to use the sunroof.
Fix central locking. Sometimes you cant lock the car at all
Obtain a second key, only having one makes me nervous!
Passenger front window doesnt work. It did when I got the car, albeit very very slowly. Doesnt work at all now
Find the following trim bits:
* both front door lock buttons/pins
* replacement height control lever, the top has snapped off (could just pin it and glue it)
* rear drivers side door cubby hole lid
Apart from that I have a CD player to fit, then the interior needs a real deep clean. Ill probably get some tailered car mats, it has genuine citroen rubber ones but they are a bit worn
- raynoon
Re: My s1 diesel
You could fit an aftermarket central locking kit, there is a 'how to' in the self help files. It's fairly easy to do and would probably cross 3 items of your list
