Has anyone out there got a good condition gear selector for a series 2 automatic. I don't think the engine type makes much difference nor series 1/2? It has to be suitable for the 4Hp18 hydraulic box. I have had two scrap automatics and both had the same splits in the rubber T bar part. Would a Xantia fit? Citroen part number 2402 93. Oddly the series 1 one is shown as on back order but the storeman said you'd wait a long time if ever to get one because of minimum order threshold or something like that. It has the part number 2403 J0.
Ian
Gear selector for automatic wanted
Onion Johnny
- Orga / RP numbers: RP7302 Silver 01/1997 Series 2 Hatchback. 2.0 TCT
Re: Gear selector for automatic wanted
I think i have one.. xm used same lever right through from 89 to last V6 2000.. early mk.1 xantia autos also did use it.. plus zx autos and i think if found bxs too..
Onion Johnny
If it is in good condition I'll take it.
May be worth a trawl of local scrappy too.
Bx is different design well the one I saw.
My email is fiatson(at)aol(dot)com if you want to send some details or O7 5 129 4 38 1O for text/talk.
Ian
Ian
Located and ready for you..
