XM Clearout
boyse7en
XM Clearout
Post by boyse7en »
I've got a load of bits and bobs left over from my 15 years of XM ownership.
Offers invited for any of the bits listed below, or will put on ebay if several people are interested.
Brand new, original, primered front nose panel still boxed
Lock set for XM with ignition barrel and several keys
Front and rear seats from a 2.0SX 16v model. They are fabric, not leather, but were in good nick when I took them out.
electric window frames and cables
Mk1 Clarion radio cassette player
O/s driveshaft assembly. Came from a 2.1 Diesel hatch.
Electric window switch
Mk1 Front Grille blade in Dark metallic green
May be some more bits, I'll have a look through
1999 Alfa Romeo 166 V6
1977 Triumph Stag 3.0 V8
1984 Tiger Cat E1 2.1
1977 Austin Mini 1380cc
2000 Ducati Monster M600
2006 BMW F800S
cxprestigeauto
Re: XM Clearout
Post by cxprestigeauto »
PM sent
boyse7en
Re: XM Clearout
Post by boyse7en »
How can I add pictures to these posts?
2006 BMW F800S
boyse7en
Re: XM Clearout
Post by boyse7en »
At last!
Pic of the nosecone.
Box sticker says it is "Y41 Calandre PH2 MP"
7804E5
2006 BMW F800S
Re: XM Clearout
That is a Series 2, or Y4 nosecone. (Note the Y4 designation in the part description)
boyse7en
Re: XM Clearout
Post by boyse7en »
It is a MK2, the grille is different to the MK1
2006 BMW F800S
Re: XM Clearout
There are two variations of the Mk 2 grill with chevron size changes.
Chevron panel screws in from the rear and can be swapped.
Mk 1 grills have thinner centre fixings so the Mk 1 headlamps have 5mm projections to match.
To fit a Mk 2 grill to a Mk 1 the headlamp fixing projections must be cut off.
The fixings need to rebuilt further back or just ignored.
Replacement headlamps changed to all Mk 2 often supplied with a plastic 5mm spacer for Mk 1 grills.
boyse7en
Re: XM Clearout
Post by boyse7en »
Found an ABS sensor in the garage - rear fitting I think (longer cable) Not sure if it is from a Mk1 or Mk2, but they are interchangeable.
2006 BMW F800S
cxprestigeauto
Re: XM Clearout
boyse7en wrote:Found an ABS sensor in the garage - rear fitting I think (longer cable) Not sure if it is from a Mk1 or Mk2, but they are interchangeable.
Green or blue connector?
If it is green then I am interested.
boyse7en
Re: XM Clearout
Post by boyse7en »
It's a green plug
Cable is approx 85 cm from sensor to plug
Plug has Siemens Bendix written on it
2006 BMW F800S
