Last of the great 6s
Salman
Orga / RP numbers: 05149
Post by Salman » Mon Mar 27, 2017 11:18 am
From far far away in Australia.
Re: Last of the great 6s
Post by citroenxm » Mon Mar 27, 2017 8:11 pm
Look at the 04 series!! Beautifull!!
Post by citroenxm » Mon Mar 27, 2017 8:12 pm
Thats interesting.. your 605 has 607 v6 wheels.. is the 605 also a V6?
Jan-hendrik
Post by Jan-hendrik » Tue Mar 28, 2017 12:22 am
Delft Blue body colour! Do you know the French couleur name, or alternatively the colour code?
Salman
Post by Salman » Tue Mar 28, 2017 7:34 am
Jan,the 607 shares suspension of 605,so I upgraded to Brembo front brakes and the very elegant 17 inch wheels,same overall diameter so no speedo error,checked with Gps.
Jan-hendrik
Post by Jan-hendrik » Tue Mar 28, 2017 12:25 pm
Salman wrote:Jan,the 607 shares suspension of 605,so I upgraded to Brembo front brakes and the very elegant 17 inch wheels,same overall diameter so no speedo error,checked with Gps.
Thank you for sharing these details. Must be a great car to drive. In the 1960s and early 70s I drove a 203 and 403 respectively and then a 504 for a short time, a great change up. All really fun cars to drive. But Citroen cars took over, not after a number of Japanese cars though.
Post by citroenxm » Tue Mar 28, 2017 6:48 pm
citroenxm wrote:Thats interesting.. your 605 has 607 v6 wheels.. is the 605 also a V6?
Hi it was me paul who noticed the wheels/605 .. the 607 still used the xm chassis press for the floor pan and front subframe...
Post by Dean » Tue Mar 28, 2017 8:13 pm
So i take it the 605/607 pug and XM also share the same hub carrier assembly?
So you could, if you wanted to of course, fit 4 pot Brembo's to an xm and see what the 4 pot calliper grabs like with a full power brake system rather than servo assisted setup.................
Post by citroenxm » Tue Mar 28, 2017 8:42 pm
Yes because they use the same 5 bolt wheels and the 605 used the same hubs .. so .. yes..
607 seats use identical floor mounts as the xm too.. right up to 2006 i think was 607 final years.. the 607 seats went one further and on top spec got electric headrest movement! !
Jan-hendrik
Post by Jan-hendrik » Wed Mar 29, 2017 1:44 am
Yes, I was a bit puzzled by the answer to my question about the body colour :D
