XM Turbo SED or not
Z3N85
XM Turbo SED or not
Post by Z3N85 » Tue Feb 07, 2017 8:14 pm
hi guys, im new to the forum and i have a XM 1991 2.1 Td. I have a question, how do i know if my XM is a SED? Or what is a XM SED? Mine has wood trims, sun roof, climatronic, leather seats but they aren´t heated.
Thank you.
Re: XM Turbo SED or not
Post by Dieselman » Tue Feb 07, 2017 8:34 pm
That sounds like SED trim, leather and wood are the give-aways, along with black headilining and carpets.
Z3N85
Post by Z3N85 » Tue Feb 07, 2017 8:43 pm
Yes it has all that, the interior is all black too but the leather seats are not heated? don´t have the buttons. it´s possible to have the instalations on the seats and plug the buttons?
Post by Dieselman » Tue Feb 07, 2017 9:23 pm
I don't think early XM had heated seats as an option, other than in very cold climates.
Post by citroenxm » Wed Feb 08, 2017 6:57 am
Early xm arent heated as standard i beleve it was an option as i had an sed on a H 1991 and it was heated..
Those are easilly fitted to any car the next give away is the lh display should be a dot matrix text read out display.. abs fitted and alloys too.. from the sound of it though with the digital heating unit it is an sed..
Julianw
Orga / RP numbers: 4937
Post by Julianw » Mon Feb 13, 2017 1:17 pm
citroenxm wrote:Early xm arent heated as standard i beleve it was an option as i had an sed on a H 1991 and it was heated..
Those are easilly fitted to any car ...
Hi Paul
Do tell more about adding seat heaters! Does it require swapping out the seats or can the heaters be retrofitted?
Cheers
Sent from my BV6000 using Tapatalk
Julianw
Post by Julianw » Mon Feb 13, 2017 1:18 pm
PS sorry for the thread hijack
djg
Orga / RP numbers: 7903
Post by djg » Tue Feb 14, 2017 1:11 am
Yes, there are heater kits available on the market. Slight disassembly of the seat is required.
Bye,
Gábor
Julianw
Post by Julianw » Tue Feb 14, 2017 11:16 pm
Nice. Thanks for the info
