Wanted rear spoiler rubber seals
xm24v
Post by xm24v » Thu Jan 19, 2017 10:31 pm
Wanted. Rubber seals for my S1 24V. I've had the rear spoiler resprayed, sent to bodyshop before my engine woes, so need fresh seals. Mine are all perished.Anyone got a good Pair? As the 24V it's the spoiler that stands on 2 pedestals. Thanks. I need something to take my mind off the possible destruction inside the engine. See my post in petrol engines......
1991 XM 24V S1
1991 Renault 25 2.9i Baccara
1994 Renault Safrane 3.0i RXE
1984 Talbot Tagora SX 2.6
1980 Renault 30TX auto phase 1
1980 Renault 30TX manual phase 1
1982 Renault 5 Gordini Turbo
Re: Wanted rear spoiler rubber seals
Post by russ92xmsed » Fri Jan 20, 2017 1:37 pm
I think you might find it a bit tough to get some good ones. Only Mk1 had them, so I think most would be perishing by now. You might be lucky however.
This is one of those parts that need a nifty solution for remanufactring. 3D printing in rubber would be very useful!
xm24v
Post by xm24v » Fri Jan 20, 2017 2:25 pm
I agree this may be something I need to look into. Can 3D printing print in rubber? If so there is a place in Manchester that has a massive industrial 3D printer.
1991 XM 24V S1
Post by White Exec » Fri Jan 20, 2017 6:10 pm
If a flat gasket/seal, is it possible to cut one from a sheet of something cushioning?
Post by russ92xmsed » Fri Jan 20, 2017 6:39 pm
I doubt a 3D printer can print in rubber. Maybe a plastic printed version with two thin rubber gaskets might do it. A sort of sandwich.
Or have a plastic one printed and use it as a mould to make a rubber one possibly.
Post by White Exec » Fri Jan 20, 2017 7:05 pm
Do we have a photo or drawing of this item?
Post by MTXM » Fri Jan 20, 2017 7:08 pm
It is not quite a flat seal due to there being a slight upstand/rim around the edge, whose omission would be noticeable I think! Regards, Matthew T.
Post by MTXM » Fri Jan 20, 2017 7:17 pm
Here is a photo of one of my flakey spares! Regards, Matthew T.
Post by Dieselman » Fri Jan 20, 2017 8:49 pm
The original ones are more plasticy than rubber. I made two new ones from a sheet of rubber I had.
xm24v
Post by xm24v » Fri Jan 20, 2017 9:18 pm
I may try cutting some temporary ones from a sheet of rubber and look into getting some proper ones made.
1991 XM 24V S1
