Monte Carlo alloy wanted
raynoon
Orga / RP numbers: 6043
Post by raynoon »
I'm after a good, true, Monte Carlo 5 stud alloy for my series 2, one of mine has gone out of shape.
Thank you
normanlindley
Orga / RP numbers: Ex 98 Xm Vsx 2.1 Td Auto Silver Estate RP 7548
Huddersfield
2010 C6 2.2 Exclusive in black
Re: Monte Carlo alloy wanted
Post by normanlindley »
How about taking it to a alloy wheel refurbisher and having repaired
Huddersfield Has no sunroof
I have a pile of 5 stripped of tyres that I was going to take with the next load of scrap.
raynoon
Post by raynoon »
John do you know if at least one of them is still good?
They have all come off XM's because for a while now I have been slowly replacing them with Etoile's or steel from stock.
All had been in use and properly balanced, none were curbed or balance rejects.
If you want to be sure there are a pair still on the back of the current in use exclusive.
These will get swapped early in the new year and the tyres recovered for spare wheels.
Last time I got £5 per alloy wheel and asked to prove ownership as a batch of 9 was considered unusual.
I have just got tired of having to make special arrangements every time a Monte Carlo wheel needs balancing.
raynoon
Post by raynoon »
I'm interested John, I've just had a set re-tyred at ATS and one of them is bad, so I don't need tyres. I think I can match your £5 a wheel and I don't require any ID lol
