My latest acquisition
- raynoon
- Orga / RP numbers: 6043
I'd like to introduce Percy the Peugeot 104....
We had a very exciting 4.5 hour trip back from Peterborough yesterday, he fought me most of the way but by sheer luck we arrived home in 1 piece.
Re: My latest acquisition
Wow Ray that is a real piece of 80's retro and not something you say on the road much now! I wonder what your plans are for Percy! With regards, Matthew T.
cxprestigeauto
Yep, sounds like a 104, remember being dumped with fuel starvation up the M6 in the 1980's. Our last one managed to hole a piston!raynoon wrote:I'd like to introduce Percy the Peugeot 104....
Happy days
- raynoon
Yep.... seems like a fuel starvation problem here too.... it'll run great but stall when stopped... or it will tick over nicely and misfire like a bugger on the move!
Check the coil output voltage.
Kerry CX
I own its twin brother.....same colour and same SR spec I presume. I had problems with mine lately and replaced all usual suspects. Petrol pump, coil, dizzy cap, rotor arm, condenser and points. Had to go several times to get a descent set of points which seemed to be the problem.
Then I had intermittent carb problems so cleaned carb and blew out all jets and now it's running perfect. I think you should clean the carb and if that doesn't work then do the points. To do the points you remove the distributor but it's a good idea to mark the correct timing position before you remove it.
Sent from my iPhone using Tapatalk
cxprestigeauto
Our problem was blocked fuel lines/filter and associated crud in the carb. Took a good deal of clearing.
- raynoon
It's a GL Kerry, where are you based?
- raynoon
Thanks, when the weather improves I'll have a good look round it, I got it ticking over today on a little choke. When I was trying to get it running at the motorway services last night I noticed the clear fuel filter was empty, today it was almost full, but it was weeping so I've removed it fed the fuel line directly to the carb so I can keep turning it over.
Very cool Ray. Suitcase engine ect, hope you get it running right.
I see it's the PC car.... how very French, we need XM and Percy pics!
