How do i post a topic that I saved as a draft?
p.smith
XM newbie
Post by p.smith » Thu Nov 24, 2016 10:37 pm
I have just written a post for sales and wants and saved it in drafts but now can't get back to the compiled post and the draft post does not have submit key. How do i resolve this problem? Drafts seem a bit useless if you can't post them later.
yours
P Smith
Re: How do i post a topic that I saved as a draft?
Post by Dieselman » Fri Nov 25, 2016 4:31 pm
Test draft post.
Here you are able to select the draft you want to continue writing. Your current post will be cancelled, all current post contents will be deleted. View, edit and delete drafts within your User Control Panel.
Once happy with the post, click "Submit"
Post by citroenxm » Sat Nov 26, 2016 8:02 am
Go back to compose a message then at the bottom of the draft page you get load draft box. It only appears after you have saved a draft for that section.. ... click it..
Post by Dieselman » Sat Nov 26, 2016 10:14 am
citroenxm wrote:Go back to compose a message then at the bottom of the draft page you get load draft box. It only appears after you have saved a draft for that section.. ... click it..
Have you tried that? I couldn't get it to work.
Afaik. You have to go through the User Control Panel to access the saved draft. There is a notification to that effect, once you create the draft.
Post by citroenxm » Sat Nov 26, 2016 12:42 pm
Yup.. i did it before i posted Will other wise id not of said it
Post by Dieselman » Sat Nov 26, 2016 1:08 pm
I tried that first, but it brought up a blank text box.
I've just tried it again and now understand you then need to click ont he link above the text box. Thanks.
