A little trick ive been using demonstrated wonderfully by one of my favourite youtubists (parental advisory but funny as)
[youtube]fqZYgReuywM[/youtube]
https://youtu.be/fqZYgReuywM" onclick="window.open(this.href);return false;
Removing steel studs from alloy or desolving steel
Re: Removing steel studs from alloy or desolving steel
Hi Dean
That's a bit of chemistry that either I didn't know about or have forgotten, very interesting.
I remove my broken bolts/studs by welding a nut on the end, even it it broken off flush, providing you can keep the nut in position you can weld it, the application of heat plus the extra purchase you can get on the nut works a treat, every time for me.
