Wanted: Front electro-valve for mk1.5 car
sdelasal
Post by sdelasal »
My front EV mounted on the centre sphere block is leaking when the system enters soft mode- leaking as in visible drops rather than an internal leak. So any advice on how to remove it would be welcome and also has anyone got a spare that I can buy or borrow - as i'm reluctant to remove my one until I have a spare in my hand. Steve
added: as shown here. http://www.nn.cl/Autos/XM/pdfs/Electrov ... sembly.pdf" onclick="window.open(this.href);return false;
Re: Wanted: Front electro-valve for mk1.5 car
Post by xantia_v6 »
You might find some inspiration in http://www.frenchcarforum.co.uk/forum/v ... =3&t=32782" onclick="window.open(this.href);return false;
sdelasal
Post by sdelasal »
Yep, that's the bad boy!
Post by xantia_v6 »
My subtle point was that internal leakage in soft mode can often be cured by dismantling and stretching the small spring a little.
sdelasal
Post by sdelasal »
Thanks, but it's an external leak that is the problem - I've now corrected the original post to say as such.
Sent from my HTC Desire S using Tapatalk 2
Post by xantia_v6 »
An external leak only in soft mode seems unusual.
Are you shure it is not just a split or disconnected return hose? On one of my Xantias (which had a valve with a lot of internal leakage), the spike of pressure when changing modes was enough to pop-off the return hose, until I fastened it with a cable tie.
