2.1 TD Headgasket supplier
So the head is off, I now need a headgasket to put her back together..
So, Ebay is now useless for them, Im looking for a THREE NOTCH Gasket for this XM please...
Any advise for where to get one be great!
Re: 2.1 TD Headgasket supplier
Mister Auto - Payen - DV150, possibly.
Cheers Chris..
Can someone just help confirm which one is the three notch gasket...
I think its the 422.531 gasket.. I assume the bit under each gasket illistration is the Notch/Hole format..
http://www.mister-auto.co.uk/en/cylinde ... _g318.html" onclick="window.open(this.href);return false;
Not sure. Someone will know.
Look at the Payen gaskets a bit further down
- notches visible (but check it's not a generic photo!)
- Peugeot OE number listed
I went on service citroen.. but they like everyone else gave dimensions in MM not notches so I was none the wiser, the PSA part numbr is correct though... There was only two gaskets still available from the dealer, the rest NFP... and a cool 100 quid for one..
Did see that one still-available HG on s.c. £100, gosh.
Citroen repair manual or datasheets will probably give you thickness/notches info?
Looking at the Elring gaskets, 3 notch is 1.67mm.
