L reg XM 2.1 TD Estate parts for sale
Southerneruk
Post by Southerneruk »
loads off parts to many to list, just ask if I still have any, if I have then just make an offer.
Keith10
Orga / RP numbers: XM 2.1 TD auto hatchback RP is 6045
Re: L reg XM 2.1 TD Estate parts for sale
Post by Keith10 »
Hi Do you have:
1) Complete RHD drivers side mirror?
2) Curved black plastic cover immediately in front of drivers side mirror than rolls off the bottom of the windscreen immediately behind the bonnet.
3) RHD Front side ABS sensor (wheel speed sensor cable) with green plug. May be interested also in the other wheel sensors passenger side and rears
Any pics would help to email keith.stpeter@gmail.com
Hope you can assist
Best Regards
Keith
Southerneruk
All wheels senors was shot. that curve bit plastic not sure but think i put that on my xm that I drive. I know I do have 1 mirror still attach to the door I will check to see which one it is
Southerneruk
If you go onto
https://www.facebook.com/groups/6507032 ... 2677259953" onclick="window.open(this.href);return false;
I posted pictures on there, for some reason i can't post pictures on here.
JK99
Post by JK99 »
Hi
Have you got:
- reflector covering the amber light which signals a turn. This reflector is on the corner part of the car, rear, passenger side
- also, the red reflector above that one.
Mine got broken some time ago.
My estate is a 2.5 td, but I assume body size is same as on your 2.1td.
JK99
