Window regulator needed.
- Orga / RP numbers: 8542
Does anyone have a NOS or good used OSF ie drivers front window regulator? It's the later nine pin electrical connector. No luck at local Citroen dealer. Cheers in advance.
Mark Smith.
1997 Honda Firestorm.
Re: Window regulator needed.
Seems to be a que for these now..
I need one for a 2000 XM .. You need one and theres another member wanting a 2000 regulator too!!
I think mark has sourced one now according to Facebook
Im still after one though..
There are two versions of the window winder 9 pin connector used on Mk2 XM's.
Early Mk2's use a Citroen thin spring clip lock, later ones use a Pug red slide lock.
Electrical connection pins are identical for both.
Polarisation slots and ridges are varied to prevent interchange.
If a problem this is usually bodged but it destroys the locking on a plug hanging under the motor.
It is possible to swap the cases but that involves striping and rebuilding the control motor.
I would think the same assembly is fitted to a number of Peugeot / Citroen cars.
If you can wait until next month Paul I believe both Dave's doors have working regulators! Regards, Matthew T.Im still after one though..
I've managed to source a s/h one off a fellow Citroenista. Cheers guys. Don't get much of a chance to frequent the forums these days sadly. With losing Mum last year I'm busy being Dad's carer.
Mark Smith.
Take care of yourself, Mark. Know that kind of responsibility.
Enjoyed your regular posts.
It is good to see you on the Forum again Mark and hopefully we may meet at the National this year! Regards, Matthew T.
I know how you feel mark, i am the same but the other way round looking after my mum which is a 24 hour job and no rest bites
