Hi, I'm after a couple of switches from a series 1,
I need an electric arm rest switch
And an ash tray OR stereo release button (it's actually the little Spring inside so either will do but pref the ash tray flap release)
Cheap as possible please!
Switches wanted
- raynoon
- Orga / RP numbers: 6043
Switches wanted
Re: Switches wanted
Shout Ray!!!
Can do the arm rest switch... Though a rear window switch crom centre comsole does the same job..
- raynoon
Re: Switches wanted
Thanks Paul.
Southerneruk
Re: Switches wanted
I kept all the center consal stored in gargage, I should have the other parts you need. give ray a call first.
- raynoon
Re: Switches wanted
Which Ray shall I call?
Southerneruk
Re: Switches wanted
The one citroenxm says give a call, they are more likely to be closer to you than I am
- raynoon
Re: Switches wanted
I'm confused :-/
Re: Switches wanted
I didnt say call ray. I meant give me a shout Ray... As there is TONS of bits of switchs here
Southerneruk
Re: Switches wanted
Well I was close citroenxm.
Re: Switches wanted
Lol... Yes..
