wanted: Citroen XM 2.0 TURBO MT lower engine bracket
icrc
Post by icrc »
hello,
I want to find these parts in the red circle, anybody could help me?
lower engine mounting bracket(for manual gearbox):
parts of gear change control
thank you very much!
Eric Chen
icrc
Re: wanted: Citroen XM 2.0 TURBO MT lower engine bracket
Post by icrc »
by the way,
these parts are the same with 2.1TD one
do me a favor, please...
Deafentaly same as 2.1? Ive a couple of 2.1 td engines out of cars that I stripped completely last year
I have a tct lower mount bracket with a good bush in it, no good to me as its different to the N/A engine, if Paul cant find anything let me know.
icrc
Post by icrc »
citroenxm wrote:Deafentaly same as 2.1? Ive a couple of 2.1 td engines out of cars that I stripped completely last year
I think so...
if 2.1TD use ME5T gearbox(which use clutch cable, not hydraulic one), the gear change control and lower engine mounting bracket are the same with XM 2.0 CT
or
MG5T or ML5T use cable-type gear change control, are different from ME5T...
could you help me to check the car you'd stripped , are there these parts I need still there?
CitroRS
Post by CitroRS »
I can have a look here in Serbia at guy's that has some XM parts if you want. It's this 1807.A2 part marked on last image, models since February 1st 1994?
icrc
Post by icrc »
CitroRS wrote:I can have a look here in Serbia at guy's that has some XM parts if you want. It's this 1807.A2 part marked on last image, models since February 1st 1994?
yes, waiting for your good news!
if he have 2449.80(control return) and 2452.52(gear shift link) in the second photo, that will be wonderful!
Eric Chen
CitroRS
Post by CitroRS »
Ok, I'll see what I can do tomorrow. :)
CitroRS
Post by CitroRS »
Hi Eric, I managed to track down engine mount - I've PM'd you details. : )
